• 11.11.2026, 06:15
Leakshield Display Control
Friday, December 9th 2022, 4:21am
I have some questions about the Leakshield Display control. The layout and options are different than the High Flow Next and D5 Next Display options.
1 - In the LKS display tab in AQS there are 10 display pages. There is no option to add a page but there is an option to delete a page. If I delete a page, can I then add it back? I have not tried deleting a page because I don't want to permanently lose a display page. The manual says nothing about this.
2 - For each of the 10 pages, I can select "Show in Standby State". If I click that, another option appears to "Hide during normal operation". If I check Show in Standby State and Hide in Normal Operation for all 10 pages, the LKS Logo page is still displayed. Is this page different than the other 9 pages?
3 - To preserve the OLED display, I have Brightness set to Low and Brightness when Idle set to Off. What is considered "Idle"?
4 - When the display is set to Low Brightness, if I change it to Maximum Brightness it changes to Maximum Brightness. If I then change it back to Low Brightness, it stays at Maximum Brightness until I select another page. Why doesn't it immediately go back to Low Brightness?
This post has been edited 1 times, last edit by "Speedy-VI" (Dec 9th 2022, 7:20pm)
Friday, December 9th 2022, 7:05am
1. You have 10 pages, the deletion refers to the content of the page, if you delete it you will see only a + in the preview.
You do not lose a page by doing this.
For the rest i´m not sure.
Friday, December 9th 2022, 7:19pm
Thank you. I was pretty sure that deleting a page would not result in a permanent change. If nothing else, I could always return the device to factory defaults. The LKS Display set up is different than the D5 Next and High Flow Next, I think because the LKS is intended to remain powered and functioning when the computer is shut down. It's kind of confusing, at least to me. The other issues I noticed are minor, and may be bugs or maybe I am just not understanding something.
Ytterbium
Saturday, December 10th 2022, 11:57am
I think the idle is a time out.
