• 07.11.2026, 13:16
Ytterbium
Quadro Curve Shape
Wednesday, December 14th 2022, 8:52pm
I'm setting up my fans.
If the curve shape for a fan custom to each fan or a global setting?
When I switch between the different ones it seems to reset to the other curve, just not sure how it supposed to be?
MotoMazz
Wednesday, December 14th 2022, 10:23pm
If the QUADRO is the same as the OCTO or even the Aquaero, you will have 1 curve controller per fan output, so you SHOULD be able to control each fan output individually using a curve controller.
With the OCTO, it's pretty clever, because you can set up one curve controller and then copy those settings to the other 7 fan curve controllers. I'm pretty sure the same goes for the QUADRO.
This post has been edited 1 times, last edit by "MotoMazz" (Dec 14th 2022, 10:25pm)
/MotoMazz
Remayz
Wednesday, December 14th 2022, 10:38pm
when you've made your fan curves, go to the profiles tab and SAVE the damn settings to one of the Quadro profiles :p
Otherwise, when you change profiles, all your hard work is lost
Wednesday, December 14th 2022, 10:42pm
As MotoMazz stated, each port has it's own controller. If you want a global setting, make a controller for a fan, then copy to the other fans. (SHORT CLIP)
Ytterbium
Wednesday, December 14th 2022, 11:56pm
I think it a bug in aquasuite then since it just doesn't display it correctly.
Thursday, December 15th 2022, 2:46am
Any screenshots you can share?
Ytterbium
Thursday, December 15th 2022, 11:14am
I started with both fans with 0 curve, I then edit this fan to give the 20 curve.
When I switch to the other fan you can see its like the curve from the other fan is in settings, although I assume based on comments that isn't true, and the picture shows that its still linear
Thursday, December 15th 2022, 11:32am
The slider is ONLY for a initial curve shape setup.
When you switch between the fans you have one indivual curve for eache fan.
Everything looks right so far.
Ytterbium
Thursday, December 15th 2022, 1:35pm
OK, I find it a little confusing from a useability perspective but I get your point.
Thursday, December 15th 2022, 1:40pm
If you drag and drop points manually or change values, what should the slider adjust to?
This is only possible during the initial creation of a curve.
Similar threads
