• 18.11.2026, 03:41
sworfiss
Octo Fan 4 acts up strangely - Please help!
Saturday, December 24th 2022, 5:24am
Hello Everyone,
Amazing Octo, Leakshield and High FLow impressed me every times, controlling fans at ease. I will share the snap of PC soon. :)
After a few weeks, One fan 4 acts in surprising way as RPM is going to increase at 10% and decrease at 90% :/.
I tried to reset the controller, but it is still the same. Please have a look at 2 images. Is there any way to fix the solution?
Please help!
sworfiss has attached the following images:
This post has been edited 3 times, last edit by "sworfiss" (Dec 24th 2022, 5:26am)
Saturday, December 24th 2022, 6:12pm
Have you tried swapping fan 4 with fan 3 or 5 to see if the issue follows the fan or the port?
sworfiss
Saturday, December 24th 2022, 8:33pm
Yes I had swapped different fans on 4 port, Reversal issue appeared. I even set one follow to another port, but same issue
Saturday, December 24th 2022, 10:35pm
Inverted control without input offset is something I have not experienced.
You mat be best served contacting support: support@aqua-computer.de
sworfiss
Sunday, December 25th 2022, 5:55am
Sure, Ill mail it. Thanks
Do you know how to import HWinfo data into Aquacomputer data without HWInfo loaded?
Sunday, December 25th 2022, 12:20pm
If HWiNFO is not running, there are no data to be imported from it.
You could see if the aquausite Hardware Monitor reads the sensors you are interested in.
sworfiss
Sunday, December 25th 2022, 2:25pm
Great, Changed sensors to Aquasite Hardware monitor, hope Aquasite sensors are as accurate as HWInfo
Similar threads
