• 17.11.2026, 16:06
Dundys
Taking Front Display of 6XT
Monday, December 26th 2022, 1:47am
I'm not sure if this was cover anywhere in this forum, with my luck probably, but I will still ask anyways and hope to get some info from maybe someone who either did what I'm hoping to do or who knows whether I can or not do it without losing the functionality.
Atm. My PC case is big enough to accommodate front bay accessories in which I have installed auqaero 6XT and controls only fans. Soon I'm moving to smaller case that wont be able to accommodate my XT and since I never use display, I'm wondering if I can take the front display off and just mount it somewhere inside the case like LT and connect my fans back on and if all will work as normal. I don't use remote control, but aquasuite is configured with temps sensors to control fans, would all still work as normal?
Thanks guys
This post has been edited 1 times, last edit by "Dundys" (Dec 26th 2022, 2:47am)
Monday, December 26th 2022, 3:18am
Yes, remove the display module and it becomes an LT
Dundys
Monday, December 26th 2022, 3:58am
Thank you InfoSeeker!
Will I be able to import my old settings as far is fan curves or would I have to go and set them from scratch. Also, because XT will becoming LT will that change anything with my license for aquasuite as I did renewed few months ago.
Thanks
Monday, December 26th 2022, 11:12am
Most everything in memory on the aquaero (curves, Profiles, etc.) should remain the same.
Being it is going into a new system, you will need to update your sensor sources, particularly in Software Sensors, Overview Pages, the Playground and Profiles.
Be sure to export device settings and overview pages to a thumb drive in case something glitches.
Dundys
Monday, December 26th 2022, 5:38pm
I appreciate your help, thank you.
Merry Christmas and Happy New Year :)
