• 04.11.2026, 15:37
LoudAR
leakshield membrane help
Tuesday, February 14th 2023, 4:40pm
So just 6 months ago, I set up my aquacomputer waterblocks along with leakshield and d5 next pump (ULTITUBE 150 bundle). I ordered everythingb except for a proper coolant. So what i did was added distilled water along with biocide/concentrated liquid from Barrow (because barrow was the only such liquid available in my country).
6 Months later, opened up my PC, found all the TYGON 3603 tubes stained with pink colour (since i used red liquid in 1 litre of distilled water). Waterblocks and rads are fine, no stains at all. Now problem is that little cotton in middle of LEAKSHIELD, its pink.. should i wash it? soak it? i dont want to buy a replacement as yet cause i cant really import stuff in my country these days due to government's policy. Pls see pics n advice.
LoudAR has attached the following files:
Hufeisen
Tuesday, February 14th 2023, 5:48pm
Buy Isopropanol (Isopropyl alcohol / IPA), put some drops of it onto the pink membrane, then carefully touch the membrane with a sheet of toilet paper (or something similar) to remove the Isopropanol. Do not rub.
If that does not work, you can buy a replacement membrane here: https://shop.aquacomputer.de/product_inf…roducts_id=4192
