• 17.11.2026, 17:56
omgrubberduck
Unable to install Aquasuite X.67
Thursday, March 9th 2023, 10:56pm
Getting an error stating that I don't have .NET 7 Runtime even though I definitely do. See image below.
Tried having just the x86 one installed, nope, just the x64 one, no change either. I'm downloading from the link given in the installer.
Methodical
Thursday, March 9th 2023, 11:33pm
Is it this one that was posted in the Change Log?
New: aquasuite X
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
omgrubberduck
Friday, March 10th 2023, 7:55pm
Yes I tried that one too, which is the same one linked in the installer. But it still gave me the same issue.
Friday, March 10th 2023, 9:30pm
Uninstall the x86 Version in your x64 System
LiquidMX
Saturday, March 11th 2023, 9:04pm
Same problem here
installed net7 but aqua installer x67 can't detect net7, So basicly i can not install update.
Please help
Win10 and i do not have x86 version of net 7
X299 TOMAHAWK AC
CPU: i9-10900X 4.8GHz 1.185V all Cores
Ram: Kingston 256GB 3200MHz
Cooling : Aquaero 6 XT Controller
Rad: 360 + 240 EK
GPU: ASUS RTX3090
PSU: Seasonic PX 1600
Jacob
Sunday, March 12th 2023, 12:57am
Feedback from the forum, I am version 66. After upgrading to 67, the peripherals cannot read the aquaero temperature signal,
causing the flow meter to run at full speed. In addition, the version display is still version 66.
I hope it can be replaced by an updated version, thank you. :)
-----------------------------------------------------------------------------------update>
I finally slowly know how to install the new version of AS, you must completely remove the old version including all configuration files,
otherwise you will encounter unexpected errors~! I upgraded from version 57 to version 66, and from version 66 to version 67.
I encountered the problem that the data of the calitemp temperature sensor could not be read. It can be restored to normal after completely removing it and reinstalling it. :)
This post has been edited 2 times, last edit by "Jacob" (Mar 14th 2023, 10:35am)
Sunday, March 12th 2023, 12:49pm
Uninstall all net 7 frameworks, net core, SDK.
reboot windows.
Install the correct desktop net 7 version.
Try install the aquasuite. These problems occur when you have a misconfigured window.
LiquidMX
Sunday, March 12th 2023, 8:52pm
reboot windows.
unfortunatelly this didn't work at all for me , tested 3 times with same conclusion, installer cannot see .NET 7.0.3 installed .
X299 TOMAHAWK AC
Rad: 360 + 240 EK
GPU: ASUS RTX3090
mditsch
Monday, March 13th 2023, 6:17am
reboot windows.
which result do you get when doing that:
Monday, March 13th 2023, 9:51am
We have updated the installer today.
There is now an option to ignore the Net Runtime check and install anyway.
But the Net 7 Runtime is needed, without it the software will not run.
Methodical
Tuesday, March 14th 2023, 10:16am
Anyone try this and been able to get things working correctly?
LiquidMX
Tuesday, March 14th 2023, 9:34pm
CMD results below
LiquidMX has attached the following image:
X299 TOMAHAWK AC
Rad: 360 + 240 EK
GPU: ASUS RTX3090
LiquidMX
Tuesday, March 14th 2023, 10:38pm
Thanks for that, installation wen't without problems and whole aquasuite running smoothly.
X299 TOMAHAWK AC
Rad: 360 + 240 EK
GPU: ASUS RTX3090
Methodical
Thursday, March 16th 2023, 11:25pm
To confirm. Even though it was stated that Aquasuite would not run without the Net 7 Runtime, yours is working?
LiquidMX
Sunday, March 19th 2023, 4:42pm
look above (i included image stating that .NET 7 is installed), aquasuite have trouble detecting installaion of .NET7
X299 TOMAHAWK AC
Rad: 360 + 240 EK
GPU: ASUS RTX3090
