• 30.11.2026, 22:15
Methodical
Leakshield
Sunday, March 19th 2023, 1:50am
What is the purpose of a leakshield? I know the name should speak for itself, but wanted to know why someone would use this in their system? What advantage it gives?
Thanks...
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
Sunday, March 19th 2023, 6:16am
To cut a long story short, peace of mind
Methodical
Tuesday, March 21st 2023, 7:33am
Thanks for the links.
cptninc
Tuesday, March 28th 2023, 6:20pm
I believe the purpose is to give the user as many false alarms as possible.
Remayz
Tuesday, March 28th 2023, 6:32pm
:D
temperamental little buggers ^^
I love AC, but to be honest, to me that one is the most gimmicky device of the whole catalog. If you're not all thumbs, you shouldn't need it ever. but there's nothing wrong making a buck or two to sell peace of mind :p
Regardless of how well it works, i personally am not fond of a device that is designed to vent my coolant all year long.
Wednesday, March 29th 2023, 8:09am
Not to mention the possibility to perform simple work on the system without draining the water.
https://www.youtube.com/watch?v=X5D3I-6zoaE
To see from minute 12:11
cptninc
Wednesday, March 29th 2023, 4:37pm
It's useful as a generic vacuum pump for filling loops and managing leaks during service/maintenance.
As an operational tool to detect leaks in a system, the only thing it has demonstrated that it's capable of doing is generating false alarms. I've tried in multiple systems, and on every single one of them, the Leakshield triggers a false alarm if the system goes from idle to fully loaded or from fully loaded to idle. Aquacomputer support has been unwilling to troubleshoot this behavior, so at this point, I have no option but to assume that this is normal and the device is simply incapable of operating as advertised.
Wednesday, March 29th 2023, 7:47pm
This is a pity and very strange, I use the LEAKSHIELD since its release, the only problems I had in the beginning were an alarm every time I shut down the computer and very flat tubes.
The former was probably due to too much air in the circuit, the latter to tubes that were too thin. So neither was the fault of the LEAKSHIELD.
Furthermore, there are not many error messages here that correspond to your error, so the assumption that the LEAKSHIELD generally always acts this way is rather untenable.
Remayz
Wednesday, March 29th 2023, 8:22pm
from what i've seen, alarms that are load (temperature) dependent are due to a reservoir filled up too high, leading to wide pressure variations.
maybe also an agressive pump speed curve could do that.. or a partially clogged membrane.. but i guess you went to a lot of testing already?
cptninc
Thursday, March 30th 2023, 4:22am
I tried reducing the reservoir fill to 40% (Ultitube 150) with a fixed pump speed and the false alarms kept coming. The tubing is a few short (approx 3") runs of Aquacomputer's recommended soft tubing. The pump is a D5 Next and I have a HighFlow Next as well. The loop is actually 100% Aquacomputer components except for the fans, radiators, and fittings.
