• 21.11.2026, 19:51
Tanquen
How do you acknowledge an alarm? - The Aquacomputer Calitemp Temperature Sensor Disappeared
Tuesday, May 16th 2023, 6:10pm
The overview page shows an alarm but I see no way to see what it is or ack it. Not had an alarm since I set things up. I thought I remember clearing them somehow. Man it is loud.
The system event log shows that the Temperature configuration 3, Alarm triggered. I wish I could label those.
The third Temperature alarm is looking at the "calitemp 1 in Pipe" for the data source. It's value is now ---.
In the Sensors tab the Temperature sensors has no line item for it.
On the aquabus tab it says there is no device.
I checked the Calitemp wire and it's still connected. I'm using the aquabus X4 and the Calitemp is in the port that can not be accessed while the aquaero is installed. This version has the long mounting nut sleeve.
This post has been edited 2 times, last edit by "Tanquen" (May 17th 2023, 1:00am)
Tanquen
Monday, May 22nd 2023, 3:57pm
After a power cycle the temperature sensor came back. ???
Would still like to know how to ack alarms.
Tuesday, May 23rd 2023, 5:19am
I don't use alarms, but it may be impossible to turn the alarm off while an alarm condition exists.
If that is the case, you may be able to use INPUTS to spoof the alarm condition.
Tanquen
Wednesday, May 24th 2023, 9:12pm
I may look into that.
I hate getting old, I'm sure when I was first setting it up and was messing with alarms there was a screen where you could see there state and ack them. ???
This post has been edited 1 times, last edit by "Tanquen" (May 24th 2023, 9:37pm)
