• 22.11.2026, 15:09
L0wPull
Moving to a new mobo and reinstalling OS and latest Aquasuite but keeping same AC gear - how to not lose complex settings?
Tuesday, June 13th 2023, 1:33pm
Hi there, hoping you can help! Worried.... :wacko:
I will soon move to a new mobo and fresh OS install on the pc that controls all my loop - 3 quadros, a Next, plus a farbwerk360.
I am currently on X.59, and will install the new X.68 as part of the process.
I will not be changing ANY of the physical aquacomputer gear (I read that some settings are linked to the serial numbers of the devices?)
If I make a copy of the "C:\ProgramData\aquasuite-data" directory on my current X59 setup, and after installing X68 on the fresh OS, can I simply copy over the contents of the old directory to the new installation and recover my settings?
In particular, I have some complex logic virtual softare sensor for auto-levelling flow rate, and a touch panel display config that took me a long time to get even this far
L0wPull has attached the following images:
Tuesday, June 13th 2023, 2:29pm
There have been other posts asking this question. IIRC, Aquacomputer said to manually create the directory C:\ProgramData\aquasuite-data and put your backup files in it BEFORE you install Aquasuite. That way, when it installs, it will see the old files and not create new ones. I am not 100% sure about this.
Remayz
Tuesday, June 13th 2023, 5:36pm
I did this last weekend. definitely copy the data files BEFORE installing :)
It works when you do it after but it's better to avoid the numerous reboots and potential mishaps. I only had a Foreigner moment when my Vision appeared in double.
All fan curves, lighting, virtual sensors, inputs etc carried over.
Even the sensors using HWinfo as source started working as soon as HWinfo was reinstalled and set up.
Tuesday, June 13th 2023, 11:06pm
Thanks for confirming. I was pretty sure it is recommended to make the directory and put the old files in it BEFORE installing Aquasuite, but I was not 100% sure, and I have not had to do it (yet). I would hate to give someone incorrect information (which is why I said I was not 100% sure).
L0wPull
Wednesday, June 14th 2023, 8:16am
Thank you both for this - after searching for answers I would have done it wrong way round, this does somewhat make me less nervous now...
Thanks again, i'll confirm the result when the job is done! Cheeeeers! :thumbup:
L0wPull
Wednesday, June 21st 2023, 9:52am
Very happy to report the reinstall happened with no problems at all.
Zipped up the C:\ProgramData\aquasuite-data as instructed before OS reinstall.
Extracted contents back to same directory after windows install, before launching AquaSuite install - upgraded to latest version also X68 from X59 IIRC.
During install you're prompted to keep settings or clean install, choose keep settings, enjoy! :)
ty again for the help!
L0wPull has attached the following image:
Thursday, June 22nd 2023, 2:30am
Thanks for confirming that putting the old files in the proper directory worked. I haven't had to do this yet but I am sure the time will come when I will.
