• 19.11.2026, 04:52
EmInterrupted
After Aquasuite X.72 update, software says it is not activated and cannot connect to server
Tuesday, August 15th 2023, 6:01pm
Hello, I just updated my Aquasuite to X.72 and immediately after reboot, Aquasuite now says it is not activated. In settings, I see an error that the connection to the server has failed and to check my internet connection or try again later. Since it was just working prior to the update, I'm wondering if this is an issue with that update or if there is a current server issue on the AquaComputer side? My internet is working normally. Thanks!
Saschman73
Tuesday, August 15th 2023, 6:30pm
same here!
Tuesday, August 15th 2023, 6:41pm
This is a Problem with the Server, try it again in a few hours.
Dops
Tuesday, August 15th 2023, 6:50pm
Same here.
Do we have to restart the pc/suite/service afterwards or will the service automatically connect to the server?
Tuesday, August 15th 2023, 7:01pm
This is a Server Problem. We cant say when the infrastructure is running. Try again later.
Dops
Tuesday, August 15th 2023, 7:06pm
I didn't mean that, but thanks for the reply anyway.
suty455
Tuesday, August 15th 2023, 7:56pm
can it just be left to run in the meantime in an unactivated state am assuming it will keep the background settings as it was?
xinu00
same problem after update - octo and high flow next are not recognized
Tuesday, August 22nd 2023, 11:56am
same here !
good to know, hopping for a quick fix, because its not a good place to be guys, we can't see ! lol 8)
Edit : with the excellent customer service figured out the problem was a busted internal usb header from a hub, nothing to do with the update in the first place ! cheers ! :thumbup:
i see now :P
This post has been edited 3 times, last edit by "xinu00" (Aug 22nd 2023, 4:28pm)
Tuesday, August 22nd 2023, 2:34pm
Everything is working with the Activation!
