• 30.10.2026, 03:18
Recoil
Change Up Time From Seconds to Hours
Friday, September 8th 2023, 7:06am
Hi Folks,
In Aquasuite when I try to create a new item and add the data source for "Up Time" it is displayed in seconds, could this be changed to hours?
Time is another one that is set to 24 hours instead of 12 hours, can this data sources be changed? Thanks.
Friday, September 8th 2023, 1:39pm
Uptime may be converted to decimal hours by making a Virtual Sensor (hours_up.jpg)
The 24 hour, hour result may be converted to the 12 hour format by making a Virtual Sensor (12_hour.jpg)
Recoil
Friday, September 8th 2023, 6:50pm
Thank you! I appreciate your help.
Recoil
Friday, September 8th 2023, 7:40pm
Could I ask you if you could share your Coolant/Ambient delta? Thank you once more.
Friday, September 8th 2023, 11:28pm
It's basic (delta.jpg)
Recoil
Monday, September 11th 2023, 4:18pm
Thank you very much, trying to see as many examples as possible, I wish it was easier to find more info or templates to use with virtual sensors.
Monday, September 11th 2023, 4:46pm
You may find some of KayBee Tech's videos helpful.
https://www.youtube.com/@KayBeeTech/videos
Recoil
Monday, September 11th 2023, 9:43pm
Thank you, that helps :)
Similar threads
