• 19.11.2026, 12:57
CaptainOblivious
Farbwerks 360 - Changing Brightness for Profile 1 Changes Brightness for Profile 2 as well?
Saturday, October 21st 2023, 4:44am
I have 2 "LED controllers" set up with different color schemes for each component on one of my Farbwerks 360s.
One LED Controller is slaved to Profile 1 with one color scheme.
One LED Controller is slaved to Profile 2 with a different color scheme.
I wish to have 15% brightness for Profile 1, and 100% brightness for Profile 2. But when I change the LED Strip brightness on Profile 1, it also changes the brightness for Profile 2. It is like they are linked and I cannot change the brightness per Profile, but instead the brightness is used universally across all profiles.
This means if I want to switch to a low brightness Profile 2 then change back to the high brightness Profile 1 after gaming: I can't. I am either stuck with the same brightness for all Profiles on that Farbwerk 360, or I have to go in and change the brightness manually which defeats the purpose of having multiple profiles and using the Hot Keys (Alt+F1/F2 etc.) to switch between them.
Is there any way to do this or am I stuck with the same brightness level for both Profile 1 and Profile 2? I hope I am just not setting it up correctly.. Please advise one way or the other. Thank you!
Screenshot here:
https://imgur.com/a/NBGnZBi
Remayz
Saturday, October 21st 2023, 12:44pm
yep. as far as i know, the brightness control is for the RGB output, not for the profile, so it's the same across.
What you can do is just select the same colors but darker for profile 1, and bob's your mother's brother.
CaptainOblivious
Saturday, October 21st 2023, 12:57pm
Thanks mate! I just turned the setting for darkness all the way down for profile 2 and it was the same as having it off/dimmer brightness. Problem solved!
