• 05.10.2026, 23:09
Bartdude
Power Measurement
Friday, October 27th 2023, 8:49am
Since my MPS400 gave up the ghost I finally managed to get my hands on the high flow NEXT 8o but how do I get the flow measurement into Aquaero 6 to setup a power measurement, do I require attaching the high flow NEXT via Aquabus or is there another way to do it?
Friday, October 27th 2023, 11:16am
aquabus would be the easiest solution and requires this cable.
Well, you could also do it like the cool kids and recreate this value in the playground with a virtual software sensor 8)
virtual_sensor_power.txt - please rename the file extension from .txt to .xml and import it. Afterwards you have to assign the sensor values from your system as data source.
Friday, October 27th 2023, 12:35pm
The high flow next has an integrated dissipated power calculator also.
If the high flow next is situated @ radiator in, add a temperature sensor @ radiator out to the external temperature sensor on the high flow next.
Friday, October 27th 2023, 4:57pm
[attach]10508[/attach]
[attach]10509[/attach]
I did not know this so thank you for posting it. This is described in the High Flow Next owners manual. Don't know how I missed it.
Methodical
Sunday, November 5th 2023, 3:09am
Curious. What is the purpose of monitoring pump power?
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
Sunday, November 5th 2023, 3:33am
The function attempt to determine power (heat) dissipated bv the radiator.
If you have alternating radiators & waterblocks, you will need to have temperature sensors at in/out of each radiator, make the calculation, and add them up for total heat dissipated.
