• 04.11.2026, 13:50
Kellly
High Flow Next Issue
Sunday, October 29th 2023, 8:00am
The high flow next has been working properly up until recently for me. My issue is that it is not reporting flow rate properly when it used to report it no problem. It is showing 0L/h when my pump is set to 100% rpm when it used to say 180 L/h at that same speed. How do i address this issue?
Peter von Frosta
Sunday, October 29th 2023, 8:31am
0 ml/h in the Display or Aquasuite?
The temperatures of the components are o.k?
Any Ball Valve accidentally closed?
Any Hose kinked?
Can you provide a Picture of the "Flow Sensor Page" in Aquasuite?
Kellly
Sunday, October 29th 2023, 4:20pm
0L/h on the display, I am not currently using aquasuite. There is no ball valve or kinked hose and the temperatures are good. The only thing that is the problem is the flowrate on the display.
Peter von Frosta
Sunday, October 29th 2023, 4:26pm
Have you tried a factory resett?
Kellly
Monday, October 30th 2023, 4:28am
Yes, I have. It still stays at 0L/h
Peter von Frosta
Monday, October 30th 2023, 6:22am
If still under warranty -> send the flow sensor back.
Can you hear some noise from the Rotor?
Maybe something is blocking the Rotor from turning or something is wrong with the Hall sensors
Peter von Frosta has attached the following file:
  • Unbenannt.jpg (164.48 kB - 148 times downloaded - Last download: Sep 30th 2026, 5:18am)
