• 01.10.2026, 18:10
SeeBastion
Sensorwerte Runden in yaml
Tuesday, October 31st 2023, 12:25pm
Wie kann ich die Sensorwerte in einem Benutzerdefinierten Objekt runden? Das Objekt ist mit einem Sensor aus dem Playground verknüft und zeigt 1 Nachkommastelle, ich möchte nun auf 0 nackommastellen "Runden". Hier mein bisheriger Code:
<UserControl
x:Name="this"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
mc:Ignorable="d" d:DesignHeight="300" d:DesignWidth="300">
<Grid>
<Grid.ColumnDefinitions>
<ColumnDefinition Width="0.66*"/>
<ColumnDefinition Width="0.33*"/>
</Grid.ColumnDefinitions>
<TextBlock
Margin="0,0,0,3"
Text="Power"
FontSize="14" HorizontalAlignment="Left" VerticalAlignment="Center" FontFamily="Comic Sans MS"/>
<TextBlock
Grid.Column="1" Margin="0,0,0,3" FontSize="14" FontFamily="Comic Sans MS"
HorizontalAlignment="Right" VerticalAlignment="Center">
<TextBlock.Text>
<MultiBinding Converter="{StaticResource UnitConverter}" ConverterParameter="1">
<Binding ElementName="this" Path="DataContext.Data"/>
<Binding ElementName="this" Path="DataContext.Data.v"/>
</MultiBinding>
</TextBlock.Text>
</TextBlock>
<Rectangle VerticalAlignment="Bottom" Height="0" Grid.ColumnSpan="2" Fill="White" Opacity="0.15"/>
</Grid>
</UserControl>
Peter von Frosta
Tuesday, October 31st 2023, 1:21pm
Versuche es mal so:
Quoted
<UserControl
x:Name="this"
<Grid>
<TextBlock
Margin="0,0,0,3"
Text="Power"
<TextBlock
Text="{Binding ElementName=this, Path=DataContext.Value, StringFormat={}{0:F0}, FallbackValue=nix da}"
Grid.Column="1"
FontSize="14"
FontWeight="Normal"
Margin="0,0,0,3"
HorizontalAlignment="Center"
VerticalAlignment="Center"/>
</Grid>
</UserControl>
This post has been edited 2 times, last edit by "Peter von Frosta" (Oct 31st 2023, 1:29pm)
SeeBastion
Tuesday, October 31st 2023, 3:28pm
Hm, das funktioniert an sich, allerdings fehlt dann die Einheit hinten dran.
Peter von Frosta
Tuesday, October 31st 2023, 3:44pm
Dann musst Du die noch mit einem weiteren TextBlock hinten dran hängen.
Runden kann man nur Zahlen...
SeeBastion
Tuesday, October 31st 2023, 3:54pm
klappt nicht so recht. kann man bei "StringFormat" die Einheit mit reinpacken?
Von Python o.ä. kenn ich das so, da kann man meist das Zahlenformat definieren und Pre- oder Suffixe mit dran packen.
SeeBastion
Tuesday, October 31st 2023, 4:00pm
Ok, jetzt hat es durch probieren geklappt. Habe jetzt das hier benutzt:
StringFormat='{}{0:F0} W'
Danke für die Hilfe :thumbsup:
Peter von Frosta
Tuesday, October 31st 2023, 4:02pm
Kannst Du sogar in die gleiche Zelle schreiben wie den Wert, musst nur beim Wert etwas "Margin rechts" hinzufügen
Quoted
<UserControl
x:Name="this"
<Grid>
<TextBlock
Margin="0,0,0,3"
Text="Power"
<TextBlock
Grid.Column="1"
FontSize="14"
FontWeight="Normal"
Margin="0,0,20,3"
HorizontalAlignment="right"
<TextBlock
Grid.Column="1"
Text="W"
Margin="0,0,0,3"
FontSize="14" HorizontalAlignment="Right" VerticalAlignment="Center" FontFamily="Comic Sans MS"/>
</Grid>
</UserControl>
Peter von Frosta
Tuesday, October 31st 2023, 4:03pm
Das geht auch (ich war zu langsam :rolleyes: )
