• 29.09.2026, 10:47
frogs114
Octo + Next USB overcurrent
Wednesday, January 10th 2024, 5:36pm
I am building a new system with octo + next and when I plug one or both devices into the usb 2.0 header, my computer will not start due to a usb overcurrent. If I flip them the RGB flashes red and the computer won’t start. I’ve purchased a powered USB 2.0 splitter and it does the exact same thing. I’m not entirely sure what to do minus just removing the either one completely.
This post has been edited 1 times, last edit by "frogs114" (Jan 10th 2024, 8:20pm)
MaxTwister
Wednesday, January 10th 2024, 7:18pm
you have connect a 5 volt molex to the octo ??
:D
On CachyOS
frogs114
Wednesday, January 10th 2024, 7:25pm
Yes. It’s connected via Molex. There are no obstructions or bent pins in any of the USB sockets and I just can’t figure out what’s going on.
MaxTwister
Wednesday, January 10th 2024, 7:49pm
maybe a problem with the power supply on the 5 volt
:D
On CachyOS
frogs114
Wednesday, January 10th 2024, 8:12pm
So what do I do here? It happens if either one is plugged in.
MaxTwister
Wednesday, January 10th 2024, 8:53pm
maybe your power supply pushes only 4,37 volt its not enough
:D
On CachyOS
Bartdude
Thursday, January 11th 2024, 8:50am
What motherboard do you have and are there any bios updates for it?
PvF
Thursday, January 11th 2024, 9:55am
probably not, but perhaps plugged in the wrong way round?
Thursday, January 11th 2024, 6:27pm
It is also easy to plug in the USB2.0 header offset by 1 pin.
