• 10.10.2026, 21:16
Methodical
Ultitube 150 multiport lid? The included tube doesn't fit
Thursday, February 1st 2024, 6:33am
I have the multiport lid for the ultitube that includes an acrylic glass tube for one of the ports. The included tube does not fit the ports. Does anyone know the correct size tube for the port? I've contacted Aquacomputer in the past and never heard from them so I don't have a warm and fuzzy feeling, but hope they get me the answer. I'll send an email, but in the mean time, I'd like try and find the correct tube size.
#mce_temp_url#
Thanks...Al
This post has been edited 2 times, last edit by "Methodical" (Feb 1st 2024, 8:26am)
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
Methodical
Tuesday, February 6th 2024, 4:42am
Does anyone know the size of the acrylic tube for the ultitbue? I am getting no help from Aquacomputer.
Thanks...
Tuesday, February 6th 2024, 5:33am
aquacomputer are normally very good replying to an email... it's only been a couple of business days since your post.
What about the 100mm acrylic tube doesn't fit... is it threaded at one end?
Methodical
Wednesday, February 7th 2024, 5:47am
It is a push fit. The opening in the cap has an o-ring similar to any water cooling fitting. I figured out the size. I found some hard tubing from an old built and tried it and it fits. It's 12mm OD. I placed an order for some clear 12mm OD tube.
They replied to my email on Thursday, February 1st and said that the tube needs to be replaced and that was it. I sent 2 follow up emails asking what's the next step or, at the minimum, if they could at least provide the dimensions of the tube and I would buy the tube myself. I still have not received a response.
This post has been edited 3 times, last edit by "Methodical" (Feb 7th 2024, 6:05am)
Wednesday, February 7th 2024, 8:41am
...which is not true. You have received a reply with a tracking link for the replacement on Monday and I also replied again to your second mail from yesterday evening this morning. Check your spam folder.
Marucins
Wednesday, February 14th 2024, 1:49am
If I may interject. I also thought it doesn't fit. I mean, how hard I tried, and nothing. But that wasn't true. I had to use a really significant force to get the tube into the hole. Even the person commenting on that suggested to me - I didn't use enough force. That was true. To fit into the second hole, I had to use even more force.
https://forum.aquacomputer.de/weitere-fo…ir-tube-problem
Methodical
Friday, February 16th 2024, 10:49pm
Yes, I did receive a response and they did send a replacement that fits. However, I was baffled because I never provided my name and address for the replacement part to anyone at AQ. And, the rep stated that he was waiting for my pressure test results before going further. I responded on 2/2 with the results but got no feedback or if he did I saw no email about it (checked spam is the 1st thing I do) so that's why I sent another email then suddenly got a response that the replacement was on the way. I was ok with that but it was weird because I never provided any of my information to anyone to even know that they may be sending a package. How did you'll figure out who I was and my address because I never provided this information? Did you'll use my email address to figure it out? Either way, I have the new tube and it works now. Thanks Shoggy.
This post has been edited 3 times, last edit by "Methodical" (Feb 16th 2024, 11:24pm)
Methodical
Friday, February 16th 2024, 10:52pm
I saw your post and question before I posted my thread. This was not the case for me. The tube was too large and would not past the opening and I was not going to risk breaking anything. The replacement tube is smaller and pressed in placed easily.
