• 30.11.2026, 23:36
DartSteven
[HELP and INFO] ULTITUBE D5 200 PRO LEAKSHIELD and ULTITOP DUAL D5
Saturday, February 3rd 2024, 9:43am
Good morning,
I wanted to ask if it’s possible to convert this ULTITUBE D5 200 PRO LEAKSHIELD into a dual ULTITOP DUAL D5.
Let me explain further:
I would like to remove the final part of the ULTITUBE D5 200 PRO LEAKSHIELD reservoir to add the final part of the ULTITUBE 100 reservoir. Are they compatible? And if so, where can I find this replacement piece?
Saturday, February 3rd 2024, 9:55am
You can only remove the D5 Pump from the Ultitube and attach the Pump to the Dual Ultitop.
You cant connect the reservoir direct to the ultitop.
when you have 2 D5 Pump you can use this:
https://shop.aquacomputer.de/product_inf…roducts_id=4203
to connect your ultitube with the Dual Top.
DartSteven
Saturday, February 3rd 2024, 10:01am
Thank you very much Sebastian,
you were really fast and friendly!
thanks again
