• 16.11.2026, 03:57
matleno
Rgpx using quadro crash aquasuite
Wednesday, March 13th 2024, 6:05am
Hello everyone, I'm using a Quadro, and every time I click on RGPX, the system crashes after clicking on one of the available "LEDs". It displays the colors, freezes, and then the software closes. Already tried to reinstall it without success
Here's the error from the Windows Event Viewer:
Application: aquasuite.exe
CoreCLR Version: 8.0.224.6711
.NET Version: 8.0.2
Description: The process was terminated due to an unhandled exception.
Exception Info: System.NullReferenceException: Object reference not set to an instance of an object.
at (Object)
at fYMGmGIJXQp4YjBn6Yev.klIB7ztoTDR(Object, fYMGmGIJXQp4YjBn6Yev)
at AquaComputer.Quadro.Led.ViewRainbow.ColorChanged(Object sender, EventArgs e)
at AquaComputer.Controls.ColorSelector.JIAVrvcbDXh(PaletteColor )
at sCj3koZJF4kAb7QQrixy.klIB7ztoTDR(Object, PaletteColor , sCj3koZJF4kAb7QQrixy)
at AquaComputer.Controls.ColorSelector.zU9VtJ8fNMA(DependencyObject , DependencyPropertyChangedEventArgs )
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue)
at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange)
at System.Windows.Data.BindingExpression.Activate(Object item)
at System.Windows.Data.BindingExpression.HandlePropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args)
at System.Windows.DependentList.InvalidateDependents(DependencyObject source, DependencyPropertyChangedEventArgs sourceArgs)
at System.Windows.TreeWalkHelper.OnInheritablePropertyChanged(DependencyObject d, InheritablePropertyChangeInfo info, Boolean visitedViaVisualTree)
at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren)
at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren)
at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d)
at System.Windows.DescendentsWalker`1.StartWalk(DependencyObject startNode, Boolean skipStartNode)
at System.Windows.TreeWalkHelper.InvalidateOnInheritablePropertyChange(FrameworkElement fe, FrameworkContentElement fce, InheritablePropertyChangeInfo info, Boolean skipStartNode)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
at AquaComputer.Quadro.Led.LedViewBase.Update()
at njsvXwIJQZyZa7Lrb1Sm.klIB7ztoTDR(Object, njsvXwIJQZyZa7Lrb1Sm)
at AquaComputer.Quadro.Led.LedViewBase.n3BVvpmVNuJ(DependencyObject , DependencyPropertyChangedEventArgs )
at AquaComputer.Quadro.Led.LedViewBase.set_data(ControllerViewModel value)
at i07Ks1Iku697oKoelJ2F.klIB7ztoTDR(Object, ControllerViewModel value, i07Ks1Iku697oKoelJ2F)
at AquaComputer.Quadro.Led.LedPage.aGQVhO5WnUE()
at RZZFtIINF6pPuIakOGVy.klIB7ztoTDR(Object, RZZFtIINF6pPuIakOGVy)
at AquaComputer.Quadro.Led.LedPage.j6MVvRagoEA(Object , EventArgs )
at AquaComputer.Controls.LedTimeline.LedTimeline.SelectionChanged(Object sender, EventArgs e)
at AquaComputer.Controls.LedTimeline.LedTimelineGroup.OVqVzRk1bZU(Object sender, EventArgs )
at AquaComputer.Controls.LedTimeline.LedTimelinePanel.uFCVzs3kyy0(List`1 )
at H68s9WMYH0GIWycvk7lF.klIB7ztoTDR(Object, List`1 , H68s9WMYH0GIWycvk7lF)
at AquaComputer.Controls.LedTimeline.LedTimelinePanel.UA2VznmWjAp(Object , DragStartedEventArgs )
at AquaComputer.Controls.LedTimeline.LedTimelineItem.NRjVzaHkuMA(Object , DragStartedEventArgs )
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.Controls.Primitives.Thumb.OnMouseLeftButtonDown(MouseButtonEventArgs e)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at AquaComputer.Aquasuite.App.Main()
Wednesday, March 13th 2024, 7:27am
Reset your device to factory deafults and try it again.
matleno
Wednesday, March 13th 2024, 7:56am
already tried, tried also to reinstall aquasuite cleaning everything.
anything else about sensors and fans is working totally fine, just the crash with rgpx
Wednesday, March 13th 2024, 8:17am
Sounds like something is corrupted on your system.
Try close every other running software. When you using a other firewall or virus scanner than Microsoft, close this software.
We need a detailed sumary from your system.
Hardware, Devices, Software, OS...
matleno
Friday, March 15th 2024, 9:01am
after weeks i've finally managed to fix it erasing every stock led configuration that is already in the first install and created a new "single led" for the entire strip.
Not sure why but the stock rainbow on a portion of the strip caused it to crash immediatly after selecting the led. Now seems it's working fine even with a data source attached
thank you for your help
