• 23.11.2026, 01:22
JonnyK
Is there a way to remove quality control markings or rotate the pump casing?
Wednesday, March 27th 2024, 7:46pm
My D5 Next with Ultitube arrived with a prominent quality control stamp on the front of the pump. Can this be removed, or can the casing around the pump be rotated to hide it? I don't want to rotate the whole pump because that would rotate the control unit, just the casing. So far I've been unsuccessful.
Thanks.
JonnyK has attached the following file:
Mr. Krabs
Wednesday, March 27th 2024, 8:04pm
Try isopropanol. Maybe it works. Never use Aceton or other aggressive chemicals. In some cases a normal rubber works fine.
Noname21
Wednesday, March 27th 2024, 8:09pm
Hi JonnyK
Did you buy the pump new or second-hand?
If the pump is new, I would write to Aquacomputer. They will certainly be able to help you.
JonnyK
Wednesday, March 27th 2024, 8:34pm
This is brand new right out of the box, Ultitube Pro with D5 Next. I splurged.
Thursday, March 28th 2024, 3:28pm
Vinyl Wrap?
Ushavilash
Monday, April 1st 2024, 12:31pm
Hey hi, you may need to contact the manufacturer for specific instructions on removing the quality control stamp or rotating the casing around the pump without affecting the control unit.
Similar threads
