• 12.11.2026, 03:55
meeeeeeeee
splitty 9 active instruction questions
Thursday, April 4th 2024, 8:19am
so where is the aquabus jumper? i dont see any jumpers or switches only a pot. and what is the pot used for or is it preset and shouldn't be touched?
Thursday, April 4th 2024, 8:24am
https://aquacomputer.de/handbuecher.html…ive_english.pdf
This is a fan/PWM splitter, no aquabus splitter.
meeeeeeeee
Thursday, April 4th 2024, 9:59am
ok cool so no jumper because in the instructions it said to make sure the jumper was on aquabus but i couldnt see a jumper ... but what is the blue pot for? the little adjustable knob with an arrow on it it says level?
mditsch
Thursday, April 4th 2024, 10:03am
the splitty 9 (without active) is also an Aquabus splitter. The active is a pure PWM splitter.
for the pot: see here..
SPLITTY9 ACTIVE - active splitter for up to 9 PWM fans (aquacomputer.de)
meeeeeeeee
Thursday, April 4th 2024, 10:10am
oh awesome would be nice if they included that blurb in the instructions and would be great if they indicated which way is a higher power off point vs a lower one.
thank you im now going to install it
mditsch
Thursday, April 4th 2024, 10:24am
but the pot is also described in the manual, to which the answer from Sebastian is pointing
meeeeeeeee
Thursday, April 4th 2024, 10:35am
ok that is not the instructions i got in my box i got splitty9 instructions not the active instructions thats why i was confused. thank you! and yep i briefly looked at the pdf thought it was the same as i had since its 130am here and then didnt go any farther. im going to install it in the morning thank you!
Ushavilash
Wednesday, April 10th 2024, 11:02am
Hey hi, It's located near the aquabus connector. It's used to configure settings. The potentiometer adjusts settings and is usually preset.
