• 06.10.2026, 02:45
softlion
Issue with Aquasuite and Aquaero 6
Monday, July 22nd 2024, 6:00pm
Since a couple of days now, the aquaero is loosing its configuration and uses an old configuration instead.
That happens when it switches Global Profiles from 1 to 2, then back to 1.
All settings changes are forgot.
When you change a settings while profile 1 is active, you save, but you don't save it as "Profile 1" explicitely.
Does that should work ?
Because it's not.
PvF
Tuesday, July 23rd 2024, 5:28am
You must explicitly save your changes under the profile (e.g. Profile 1). Otherwise the changes made will be lost when you switch profiles (and only then).
It's always been that way (at least as long as I've been using the Aquasuite) and hasn't changed just a few days ago :)
