• 05.10.2026, 19:43
Stitchypoohs
Octo and High Flow Next
Friday, July 26th 2024, 4:52am
Hello and thanks for help in advance. If I'm using the Octo and Flow do I just need to use USB for each? Will all relative data and RGB from the Flow be carried over USB? I've read the aquabus is not needed, but do I need to hook up flow, temp, or RGB if I strictly use USB? Thanks again.
Friday, July 26th 2024, 7:19am
Just connect both via USB.
You can control everythink with the aquasuite Software.
Stitchypoohs
Saturday, July 27th 2024, 6:38am
Thanks for the help and reply!
