• 10.10.2026, 05:28
bluechopa
quadro rgbpx blinking when rgbpx led strips + 3rd party argb products
Wednesday, August 28th 2024, 3:39pm
I'm using quadro's rgbpx. I'm struggling with the following issues. The third-party argb product used is an arctic p14 argb fan (12 LEDs)
Connection order
1. quadro → rgbpx led strip(normal operation) → p14 argb(blinking)
2. quadro → p14 argb (normal operation) → rgbpx led strip (blinking)
Connecting with third-party products used aquacomputer's rgbpx adapter (53285)
There is a problem that the LED product connected to the lower order always blinks. If the blinking occurred only in the p14 argb fan, they would have understood that it was a simple compatibility problem.
I don't have any other company's argb products, so it's difficult to check additionally.
Anyone else having the same issue as me?
Thursday, August 29th 2024, 3:33am
I am not sure what you mean by "connected to the lower order" but your connection diagram shows that whichever thing is at the end of the daisy-chain blinks. Is that correct? When you say Blinks do you mean a steady blink at some rate or erratic flickering?
bluechopa
The translation got weird.
Friday, August 30th 2024, 6:37am
You got it right. The last device I connected is flickering
