• 07.10.2026, 17:45
Willock
Aquasuite D5 Next not updating firmware
Wednesday, September 25th 2024, 10:18am
Hi, so I just bought an Ultitube 200 with a D5 Next pump, and am trying to use it with aquasuite, it says I need to update the firmware to use it with aquasuite, however when I click the firmware update button it always fails.
I've followed the instruction of disconnecting from the PSU several times, but it's still not working.
Anyone know what to do?
https://i.imgur.com/eWPKvFu.png
Wednesday, September 25th 2024, 1:24pm
Try a different USB port and maybe also different power plug.
Disconnect everything else from the pump (fans, LEDs etc.).
You can also pull off the controller unit from the pump and try it in a different PC. Please be aware that the controller will start to beep because of the missing pump signal but that can be ignored and it is still possible to update the firmware.
Willock
Wednesday, September 25th 2024, 5:23pm
Yep, just needed reseating in another USB port.
Many thanks!
