• 06.10.2026, 12:53
Levelthoughts
D5 Next combined with more than 2 amp/25 Watts. Help.
Sunday, October 27th 2024, 11:07pm
Hello,
I was hoping to find some help in regards to safely using my D5 Next/Ultitube.
I understand the D5 Next has a fan limit of 25 Watts / 2 Amps.
I am wanting to run 6 PWM Be Quiet Pro 4 fans from my radiators, but the fans combined are clearly over powered at .50Amps / 6 Watt Input - Each.
What are my options?
Can I use a Splitty 9 active connected to the D5 Next to give the fans more power? (Beyond the 25 watts / 2 amps limitation) Allowing the D5 Next to physically control all 6 fans.
I understand I could use a Quadro or Octo but that would be all controlled via Aquasuite only and not via the Next D5 physical panel.
I now realize a Flow Next alone connected to a Quadro would have been maybe a better solution, but I have already purchsed the D5 Next Ultitube.
Thanks for the help,
Monday, October 28th 2024, 11:43am
Get a SPLITTY9 ACTIVE in addition. It will solve your problem with the least amount of effort.
I think this is known, but just to be sure: All the fans you connect there receive the same PWM signal and therefore run at the same speed.
Levelthoughts
Monday, October 28th 2024, 11:03pm
I appreciate the reply.
D5 Next Altitube + Splitty 9, to run all 6 .50amp PWM fans at the same RPM.
Sounds good as it will save me from buying a Quadro.
Cheers
Similar threads
