• 07.10.2026, 14:04
tydub93
Aquasuite not showing fan curves
Saturday, November 9th 2024, 7:16pm
I am new to Aquasuite and I am not seeing any way to adjust the fan curves. There appears to be no fan mode section that i have seen other adjust their fan curve in. If anyone could give me any pointers that would be awesome.
tydub93 has attached the following image:
Saturday, November 9th 2024, 10:10pm
It has been a long time since I used an aquaero, but look at the option in the menu above 'fans' labeled 'Controllers'.
I believe you can define your controller there, and then associate the fans you want to control, to that controller.
tydub93
Sunday, November 10th 2024, 8:13am
Thanks, actually ended up figured it out after a while. Thought it might have been an issue with my arctic fans as I read there were some issues there at some point. Didn’t realize it would be in a different location from what I’ve seen. Is that a difference between Quadro/Octo and Aquaero or just different location in newer version of Aquasuite?
Sunday, November 10th 2024, 2:20pm
Yes, the aquaero is different from the quadro/octo, which have a controller for each pwm port.
Similar threads
