• 22.11.2026, 21:33
prosps
PUMP ROTATION FLOW DIRECTION
Wednesday, December 25th 2024, 10:16pm
Hi, everybody. The question is simple as a day.
Can I change the direction of the pump rotation by wires or by software?
(first generation pump D5 next with rgb light)
And if yes. How i can do this ?
Thanks for help anyway.
Remayz
Saturday, December 28th 2024, 2:34am
you can't change the rotation of the pump no, and that would just kill waterflow if you did anyway since pump tops are made for the pump to spin one way only.
if you need to reverse the flow, you'll have to swap connections.
