• 14.10.2026, 00:34
aveamurechi
One of the D5 pumps takes significantly more current (and power) than the other
Saturday, December 28th 2024, 9:27pm
I have a dual pump setup, using the dual pump mounting piece from Aquacomputer.
Both pumps are setup the same way in aquasuite, (curve controller, based on water temp).
Yet I see that one of the pumps for the same RPM takes about double the current and double the power. Any idea why that may be?
I attached screenshots.
aveamurechi has attached the following images:
Friday, January 3rd 2025, 8:24am
Hello,
you can swap the controllers of both pumps.
The value of 2.4W sounds rather implausible to me.
If it's not the controller, swap the pumps in the top.
