• 15.11.2026, 17:28
KTUS
Add new line to sensor name
Thursday, February 13th 2025, 5:42pm
In Aquasuite I have some sensor names that are long and don't fit well in the gauge representation of the sensor. For example, I have a sensor named High Flow Water Temp. On the gauge the name goes over the ring on both ends. How can I add a new line character to the name so that the name changes from:
to
High Flow
Water Temp
Yes I can make the font smaller, but then I can't read it well.
Friday, February 14th 2025, 9:43am
Check this video.
At first you disable the automatically generated name. Then you add a text block, remove its background, use
 as command for a new line in the name, set the text color to #FF04BAF0 (hex code with alpha and color) and move it to the desired position aftewards.
KTUS
Friday, February 14th 2025, 6:28pm
Thanks Shoggy. Got it to work.
