• 21.11.2026, 01:25
cwestbrook
Leakshield on ULTITUBE D5 50 PRO reservoir with D5 NEXT pump?
Tuesday, April 15th 2025, 6:06pm
Will the Leakshield work on the Ulititube D5 50 PRO reservoir with D5 NEXT pump? Didn't know if it would or not, since it's so small.
Wednesday, April 16th 2025, 2:09pm
It won't work because the air pocket in the reservoir will be too small.
Well, you could run it that way but you will very likely get a lot of false alarms and the vaccum pump has to run more often to maintain the negative pressure.
I wouldn't do it. You'll just get upset about it... ;)
