• 18.11.2026, 12:26
NHJ
Jump Testing a ULTITUBE D5 PRO fro the first time
Wednesday, April 16th 2025, 4:16pm
I have just set up my D5 pump & reservoir, along with the OCTO & Kryos NEXT cpu block.
  • I have only connected the power of the pump to the PSU through the SATA to 6pin connection for peripherals.
  • Along with a jumper block on the 24 pin power connecter for the MOBO.
I have turned the power on & get a brief sign of life via the LED's on the pump, then nothing. Am I missing something in the test setup? As I have done this with previous pumps & the test works.
Also, I have tested the PSU & it is working on its own. It's An Enhance ATX 2000watt.
Any help to remedy this usually simple operation, would be greatly appreciated, thank you.
