• 12.11.2026, 18:10
ironcobra80
Leakshield Issue?
Wednesday, April 30th 2025, 8:00pm
I just bought a second membrane because the brand new one never read more then zero. I just installed my new membrane and now read only 31 percent this makes zero sense to me. Everything else works accordingly.Using DP ultra clear.
ironcobra80 has attached the following file:
Friday, May 2nd 2025, 12:30pm
Hello,
I can't find a question in your post, nor can I find out exactly what you are talking about.
If you want a solution to a problem, it would be good to describe the problem in detail, because without that there can be no solution from other people.
ironcobra80
Friday, May 2nd 2025, 7:24pm
Hello,
My resi is 2/3 full, why is my leakshield only showing 31 percent. The original membrane only showed 0 percent so i bought a new membrane and now the new one is at 31. Is there an issue with my leakshield?
Saturday, May 3rd 2025, 7:16am
The LEAKSHIELD measures all the air in the loop, so it could simply be that you still have air in the loop.
ironcobra80
Saturday, May 3rd 2025, 9:11pm
Okay so i can assume its operating normally.
Csepeli-Piros
RE: Leakshield Issue?
Sunday, May 4th 2025, 7:12am
The negative pressure created by the LeakSield pump causes many air bubbles to form at the bottom of the water tank. I checked everything and found no coolant leaks anywhere. Reading the forum here, many people suffer from this phenomenon.Now it's my turn.On the forum, user AwkwaBear suffered from the same phenomenon, but thanks to you, the excellent helpful team, you finally solved AwkwaBear's problem with a new LeakShield part.
I have uploaded the bug report to my Youtube channel. Link: https://www.youtube.com/shorts/2f3W5l2zIUQ
Please help me !
Sincerely.
Gábor Kiss-Gergely
Csepeli-Piros
RE: RE: Leakshield Issue?
Sunday, May 4th 2025, 7:22am
Sincerely from the Aqua Computer Forum team !
Thank you for the directions !
I have posted the question on the forum link you sent me, maybe they can help. The problem is still real and I would like to solve it as soon as possible.
I think the problem is with the LeakSield sensor. There are no leaks anywhere. Unfortunately, I am at the point with the problem that even after turning off my machine, the LeakShield pressure relief indicator turns on and starts beeping.
Very annoying !
Sincerely,
Gábor Kiss-Gergely
Csepeli-Piros
RE: RE: RE: Leakshield Issue?
Monday, May 5th 2025, 6:38pm
I would like to know if you have a solution to my problem. My wife has complained that the tank in my machine has been beeping all day. Can I turn off the sound of the alarm ? Has anyone watched the video ? Please help me. If my problem is not solved, unfortunately I will have to look for a more reliable water cooling system from another brand. My nerves are out. Sincerely. Gábor Kiss-Gergely.
