• 18.11.2026, 13:56
egothrasher
Aquasuite And Lian Li
Tuesday, June 3rd 2025, 6:22am
I am running into issues with my lian li fans and aquasuite. My current setup is as follows. I have two sets of 3 fans. One set for the gpu, one for the cpu. The fans are connected to the fan hub. From the fan hub, I send the usb plug into the D5 next header. In the L connect software, I have the mb sync option selected. I want to use aquasuite to control the fans, based on the temperature. I can manually control the fans through L connect but not what I am looking for.
In aquasuite, I can control the fans via power preset. But when I try to use target temperature or curve controller, doesn't seem to be working. On my cpu, the fans show out % but no rpm. On the gpu side, the opposite is true. I see no output % but max rpm.
I don't know if I have to not plug the fan hub into the D5 next. Instead plug the fan hub into the motherboard, and then the pump into the motherboard. Because at the moment, I have nothing plugged into the motherboard. Aside from the USB cables from the d5 next pumps.
All help is appreciated, thank you!
egothrasher
Tuesday, June 3rd 2025, 7:45pm
Here are some pictures
https://imgur.com/a/NvUA0kd
Wednesday, June 4th 2025, 9:17am
Quoted
I am not sure but it sounds like you have connected the USB interface of the hub to the USB interface of the pump. That will not work of course. These ports are meant to be connected to a USB port of the mainboard.
On the other side you would not be able to use the software of both devices if you would have done that. So, your current setup is not quite clear.
I don't know that hub in detail but it must have some sort of fan input port where you would connect the fan port of the pump. This way the hub can pick up the signal and process it. That mainboard sync option sounds correct.
I am pretty sure your problem is the fan hub. Have you alredy tried to connect a fan directly to the pump?
egothrasher
Wednesday, June 4th 2025, 8:03pm
Ok I will try to explain my situation a little better. I had it working in the past before the upgrade.
I have 3 lian Li fans connected to each other. No cables, they are physically connected to each other. From the last fan I have a wire going to the lianli fan hub. From that fan hub there are a few cables. One of them is a micro USB which is plugged into an USB expansion board which is plugged into my motherboard. Then there is sata cables from the fan hub for power. The last cable, is a cable that splits into two. One head is a rgb header, the other is a USB cable header. (the ones with 9 holes, 5 wires, little black plug). This is the wire I have plugged into the fan header of the d5 next pump. (what else is the fan header for on the d5 next pump used for then?)
With aqua suite, I can control the fans via power. If I change it to 50% or 100% the fans respond accordingly. But whenever I try to use target temp or curve, the fans go to 100%. I don't know if maybe the pwm part isn't getting through.
Thursday, June 5th 2025, 4:20am
Have you read the D5 Next Manual? Sections 11.2 and 11.3 explain how to use the Target Temp and Curve Controller modes.
The D5 Next does have a 4-pin PWM fan header that can also be configured to connect a flow sensor. I don’t think it's possible to plug a standard 9-pin USB2.0 connector into this PWM fan port, and if you somehow did, it would not work. I looked on Lion Li’s site. There is a UNI HUB controller and a UNI HUB – SL L-Connect 3 Controller. If you specified which one you have, I could look at what cables are provided with it.
This is a 9-pin USB2.0 connector: If it is wired for only 1 USB port, there are 4 wires used: 5VDC, Ground, Data (+), Data (-)
This is a 4-pin PWM Fan connector:
This is the back of the D5 Next Pump:
Click on the images to enlarge. I do not see how you could possibly plug a 9-pin USB2.0 connector into the 4-pin PWM fan header on the D5 Next. Since Aquasuite is controlling your Lion Li fans, I think you have plugged in a 4-pin PWM connector from the Lion Li controller in the D5 Next fan header, and it's working because you can control the fan speed in Power Preset Mode. To use Target Temperature or Curve Controller modes, you have to assign a temperature in Aquasuite to be used as the control source for the Target Temp or Curve Controller. The D5 Next has an internal coolant temp sensor, so it would be easy to use this as the control source. Here is a snip of the D5 Next Fan Mode section with the D5 Nest coolant temp sensor selected as the temperature control source for the Fan port in Target Temp mode.
Many people prefer to set up a Virtual Sensor in the Aquasuite Playground that is Coolant Temp minus Ambient Temp (referred to as Delta-T). Doing this, of course, requires a coolant temp sensor and an ambient temp sensor. Using CPU temp is not advisable because CPU temp jumps all over the place. I suppose you could bring the CPU temp into the Playground and use the functions there to make a Virtual Sensor that is the average CPU temp, but just using the coolant temp or Delta-T would be better choices. You have not mentioned what temps you are monitoring in Aquasuite or if you have assigned a temperature sensor as the control source for the PWM fan port on the D5 Next pump. If you have not done this, the Target Temp and Curve Controllers cannot work because they are both based on a temperature, so you must assign one.
This post has been edited 1 times, last edit by "Speedy-VI" (Jun 5th 2025, 4:25am)
egothrasher
Thursday, June 5th 2025, 6:19am
I have the L connect 3 controller. From the controller there is a cable that splits. One end is the rgb cable, the other end is the 4 pin pwm. I initially had the pwm plugged into the D5 next fan header. I now have it plugged into one of the motherboard chassis fan headers. Now that its plugged into the motherboard, aquasuite doesn't seem to be able to control it at all now. Thanks for all the help so far though!
Thursday, June 5th 2025, 5:51pm
If the Lion Li PWM Fan cable is plugged into a mobo fan header, Aquasuite will NOT be able to control the fans. Aquasuite does not communicate with the mobo fan headers. For Aquasuite to control the fans, that PWM fan cable MUST be plugged into the D5 Next fan header. You had the Power Preset mode working before so you were close, but moving the Lion Li PWM Fan cable to a mobo fan header is a step backwards. If you want Aquasuite to control the fans, you have to move the Lion Li PWM fan cable back to the D5 Next Fan header. Do this, then make sure Power Preset mode is working. Then switch to Target Temp or Curve Controller mode. At this point you must assign a temperature sensor as the control source in Aquasuite. The easiest temp to use is the D5 Next built-in coolant temp sensor. I am not sure, but Aquasuite may select this temp sensor by default. If it doesn't, you have to select it as shown in my last screenshot where it says "Controller Source". Click on the plus sign and select a temperature control source.
I suggest you download and read the D5 Next owner's manual which is available in the Support section. Sections 11.2 and 11.3 explain how to use the Target Temp and Curve Controller modes. If you click on THIS LINK the D5 Next English manual PDF file will download.
