• 18.11.2026, 08:41
sylvainp
D5 pump not showing in Aquasuite
Monday, December 8th 2025, 6:14pm
I have an Aquaero 5 Pro for many years and really love it. Except only 1 PWM header. So for my new fresh build I decide to take the front display and use it as a Aquaero 5 LT, Case now don't have front 5 1/4 bay drive anymore.
In my new build I don't see my D5 pump but I use a normal PWM fan cable and plug it directly to the Aquabus High speed header. I don't see the D5 pump and no RPM so I cannot control the speed of the D5 pump.
Also in Aquasuite I don't see the pump in the Aquabus page. It was showing in my previous build.
In my previous build I think I use the Aquabus Y splitter cable with a 3 pin fan extension cable to the D5 but i'm not sure. I should have taken a picture before dissasembly !
At the moment where I place the Aquaero 5 is not reachable without having to unmount my loop.
Could the problem be because I use a normal PWM cable from the D5 directly to the Aquaero 5 Aquabus header ? On both the Aquaero 5 and the pump the Aquabus header have 4 pins.
Thanks
Monday, December 8th 2025, 9:57pm
You can not connect a regular D5 pump via aquabus. This is only possible with the D5 NEXT or the old D5 USB/aquabus variant.
I assume you have a PWM controlled D5 pump. If so, you connect its fan plug to fan header #4 and change it to PWM control in the fan settings.
sylvainp
Monday, December 8th 2025, 10:05pm
I have the D5 USB/aquabus variant and I was using it as a Aquabus device before I install it in my new PC. For some reason I lost the Aquabus device for the pump in Aquasuite. I use fan 4 (PWN) for 3 PWM fans for the top radiator.
In the aquabus I try the search for device to try to find the pump with no success.
Maybe something wrong with the cable or I will need to plug the USB cable from the D5 pump to the motherboard and make a new Aquabus adress to find it.
This post has been edited 1 times, last edit by "sylvainp" (Dec 8th 2025, 10:12pm)
Thursday, December 11th 2025, 1:50pm
If you are not using any other aquabus devices, the aquabus ID number cannot be the problem. Even though a 3-pin aquabus cable is sufficient, a 4-pin cable is usually the better choice as it is less prone to interference.
You should connect the pump via USB anyway to check whether its controller is still working properly. Unlikely but not impossible: Maybe your aquaero and pump are currently on different firmware levels that are not compatible to each other. This could also be clarified via the USB connection.
