• 11.05.2026, 21:55
Jimm0L0
Problems after last aquasuite update to X.86
Monday, February 23rd 2026, 5:07pm
after the latest aquasuite update, the software no longer detects my motherboard's sensors. It doesn't detect my motherboard at all, and it also exhibits some strange behavior. My motherboard is the one in the signature.
Jimm0L0 has attached the following image:
Jimm0L0 has attached the following file:
  • 1.jpg (70.78 kB - 134 times downloaded - Last download: May 7th 2026, 5:15am)
Gigabyte Aorus X870E Xtreme - Ryzen 9950X3D - RAM: 2x32Gb Kingston 6000 - Palit RTX 5080 GameRock - NVME: 1 Crucial T500 1Tb + 2x FireCuda 530 2x2Tb - PSU: Corsair HX1500i - Case: Corsair 7000D -Radiators: 1x420mmx45mm + 1x420mmx60mm + 1x480mmx30mm - Fans: 16x Noctua NF-A14x25 G2 + 8x Noctua NF-A12x25 G2 - GPU Block Alphacool Core - CPU Block Optimus Signature V3 Pro - 2x Utitube 100 +D5 Next - 1 Octo - 2 Vision - 1x leakshield - 1 high flow NEXT.
Monday, February 23rd 2026, 7:32pm
Your posts indicates that Aquasuite X.85 was able to poll your mobo sensors and X.86 cannot. This suggests that either Aquacomputer changed/broke something in the X.86 update or something changed on your end. Have you recently updated the Chipset drivers and/or BIOS? What is the strange behavior you are observing with X.86?
Years ago, Aquacomputer based their sensor polling on the unsigned WinRing0 Kernel mode driver. About 6 months ago, they said they wrote a new driver since Microsoft started flagging the WinRing0 unsigned Kernel mode driver as a severe threat. There are several threads about this on the English and German forums.LINK-1 LINK-2 LINK-3 LINK-4 (German) There are also a lot of posts about this mixed into other threads. Aquacomputer claims that they have completed writing a new driver and have submitted it to Microsoft for certification, but that was several months ago. They blame Microsoft for the delay in deploying this new driver. In the meantime, they have apparently moved the unsigned driver code into AquaComputerService.sys, but Windows Defender continued to flag it. They now include an option to add a security exception for it as a stop-gap measure.
Until they get their new driver signed, I decided to disable all Aquasuite direct sensor polling and import sensor data from HWINFO via its Shared Memory feature. HWINFO reports far more sensor data than Aquasuite, and it is updated far more often. The import of sensor data from HWINFO via it's Shared Memory feature works great. The only downside is that HWINFO imposes a 12-hour time limit on Shared Memory being enabled in the free version of the program. I have a lifetime Pro license which has no time limit for Shared Memory, so the time limit is not an issue. I suggest checking if HWINFO can poll your mobo sensors. It is extremely likely that it can, and if it can't because of a recent BIOS or Chipset driver update, if you post on the HWINFO forum, it will be fixed in the next Beta release within a few days. Aquacomputer usually takes much longer to address this type of thing.
Jimm0L0
Tuesday, February 24th 2026, 1:23am
Thanks for the quick response... Yes, so I updated the bios and chipset recently, but the anomalous behavior occurred immediately after the aquasuite software update together with the firmware update of my 2x D5 Next. In the image in the previous post, all the sensors that I placed on that window were correctly read... on the input source, in addition to the aquacomputer devices, my motherboard and the Corsair psu also appeared. Now as you can see in the photo, only the aquacomputer devices appear and everything else has disappeared. Another strange thing is that I created a virtual sensor calling it delta temp. which detects the temperature difference between the liquid detected by the d5 next and the ambient temperature detected by vision, the difference in these temperatures generates the curves for all my fans on the octo and everything works fine, but the delta temperature is no longer shown, even if correctly detected and applied, which obviously didn't happen before. I'll post a photo for more details... regarding winring0, yes I already knew about the issue, many software are migrating towards pawnio, even if it is still not very stable and in fact I also installed the latest version of it, 2.1 I think. However, I don't have any active antivirus installed and Windows Defender is completely deactivated... HWinfo works as well as before, except that I have the free version since I only use it when I do some benchmarks or various tests.
  • 1.jpg (70.78 kB - 46 times downloaded - Last download: May 7th 2026, 5:16am)
Tuesday, February 24th 2026, 5:09am
I also use delta-T as the control source for my fan curves. It is strange that your Virtual Software Sensor for delta-T is working, but the delta-T value is not appearing at the top like it should. The only thing I can think of that could cause what is happening is if the Aqua Computer Service is not running, or maybe if Aquasuite went into Maintenance Mode. If the Aqua Computer service is not running, you should see a message in the Aquasuite Service Tab, or just check it in Windows Services.
I always leave all Aquasuite direct sensor polling disabled and import everything I need from HWINFO, and not just because Aquacomputer is still using unsigned WinRing0 code to poll sensors. I think HWINFO is far superior to Aquasuite for sensor polling, and the author of HWINFO is very good about updating it when new hardware is released, or driver updates require changes to polling methods. Aquacomputer usually takes a lot longer to add new CPUs. GPUs, and chipsets to their polling. My view is that Aquasuite is best at monitoring and controlling Aquacomputer devices, and HWINFO is best at system-wide sensor polling. I also know that it uses a fully signed Kernel model driver while AquaComputer is still claiming that they are waiting for Microsoft to sign their new driver. I have trouble believing that Microsoft is the problem because new drivers can be Attestation Signed by the developer without passing full Hardware Lab Kit (HLK) testing. You just enroll in the Microsoft Hardware Developer Program, prepare a CAB file containing the driver binaries, .inf file, symbols, and catalog file, obtain an Extended Validation (EV) Code Signing Certificate, then upload the package to the Microsoft Hardware Dev Center. Microsoft usually processes the request within 30 minutes and provides an Attestation signed package. The whole process is automated. Once the driver is written, the Attestation Signing process should take at most a few hours, not days, and certainly not months!
I have updated one computer to Aquasuite X.86 but that computer only has an Octo attached. My main rig with a D5 Next, High Flow Next, Octo, Leakshield, and 2 x Farbwerk 360s has not been updated yet because I shut it down to do some work on the loop. I will put it back together enough to boot it up, update Aquasuite to X.86, update the D5 Next firmware, and see what happens. I don't know what the D5 Next firmware update actually does, because the Aquacomputer Change Logs are extremely vague, but they must have had a good reason to update the firmware. I say this because they told me that the D5 Next flash memory is maxed out, and they don't like messing with the firmware code unless they absolutely have to,
This post has been edited 1 times, last edit by "Speedy-VI" (Feb 24th 2026, 5:18am)
Jimm0L0
Wednesday, February 25th 2026, 11:50am
As I suspected it was a net framework problem... this morning there was a cumulative update on windows net framework, and after rebooting everything magically went back to how it was before. Thanks for the support.
Wednesday, February 25th 2026, 2:49pm
Ah. .NET Framework. I did not think of that. Good to know, so thanks for reporting what the problem was.
