• 30.11.2026, 22:20
baazaar13
Global profile system tray shows up even after being disabled.
Monday, March 2nd 2026, 4:08am
I noticed after x.86 - > x.87 update, upon wake, and login, the global profile system tray will show up (as grey/non-selected) even if I disable it. It will even show up if Aquasuite app is not running. If I turn aquasuite app on, then toggle show profile selection in system tray, it will remove it from the tray, and if i toggle it back on, it will show it, but with the corresponding profile color. Only way for me to get rid of the tray without the toggle, is to terminate the service helper. (I think). I have tried running as admin and changing setting, manually changing setting in config files, reinstalling, and even doing fixes using task scheduler. Does anyone else experience this issue after the latest update ? Any potential solutions ?
Monday, March 2nd 2026, 7:51am
this is fixed with the next update.
baazaar13
Monday, March 2nd 2026, 3:06pm
sweet :-D thx u
