• 10.10.2026, 13:10
PaulyPauly1
Show all sensors in Aida64 - To be used on LCD panel
Tuesday, April 14th 2026, 2:40pm
I just wanted to help others out who've had issues adding Conductivity - Volume - Power and any other virtual/software sensor into Aida64. By design Aida only pulls in the main sensors, Flow - Water Temp.
I created a Powershell script ('Very' Simple GUI) that pulls data from Aquasuites - Data log - Automatic Data Exports section into Aida64 backend 'DW' sensors in Windows Registry.
Takes a little setting up but works great. I have tried including some instruction withing the GUI to help.
PaulyPauly1 has attached the following file:
Wednesday, April 15th 2026, 12:59am
This is interesting. Thank for sharing. I have downloaded it for reference. The data export as a json file looks easy to set up. The PS script I will need to spend some time looking at. I have and AIDA64 Extreme license and have played around with setting up custom sensor data panels, but I have not used it much lately. Maybe its time to get back into it.
PaulyPauly1
Wednesday, April 15th 2026, 2:17pm
You are very welcome. Any more questions ask away :). Like you said it's very easy to set the Json file export up in Aqua Suite software, and the Powershell script takes care of linking whats in the Json file to Aida64. I think there are a total of 20 'DW' sensors available to use on the Aida64 backend, so you have the ability to set whatever you want up really.
There may be a way easier way of adding in the Aqua Computer sensors that currently dont show up by default in Aida64. If you find that out please let me know. :thumbsup:
1st.boss
Wednesday, April 15th 2026, 6:38pm
I can't get a flow value out of my pump at all, it would be very interesting to see the value.
HELP D5 Next 200 Pro flow calibration measurement fails?
Ei päivää ettei jotain vikaa
