• 22.11.2026, 21:12
II ARROWS
Aquasuite Profile Selection bugged
Wednesday, May 13th 2026, 4:37pm
Hello, is this the correct place to submit a bug for Aquasuite?
Basically the profile selection doesn't work, as you can see the Aquasuite correctly identifies profile 1 as active, a moderate profile, while the profile selection has the silent profile selected which should reduce the fan speed and have a more gentle curve.
It doesn't work, I have to select the profile from that page you can see in the attachment.
Wednesday, May 13th 2026, 8:25pm
This is not how it works. The profile selector changes the global profiles, not the device profiles.
Go to the tab playground -> global profiles and add an action to the desired profile that will load the device profile X for a specific device.
II ARROWS
Thursday, May 14th 2026, 12:23am
Pretty sure it worked for years, when I wasn't updating because I did not have the license...
I'll try that.
II ARROWS
Thursday, May 14th 2026, 10:36am
OK, it works that way.
