• 22.11.2026, 20:29
tmvanveelen
Load-balancing logic vs escalation with alarms
Wednesday, May 27th 2026, 2:05pm
Hi!
I'm eagerly awaiting my Ampinel order to ship, but I have a question in the meantime regarding the escalation logic. I'm not that technically minded, but I'm confused about the relation between the load-balancing and various alarms.
Let's say that I installed everything correctly and I use the 5090 Astral to render out a 3D animation; I assume that the Ampinel will monitor and load-balance the power draw, so a melted connector can be prevented? So if then an (amperage-based) alarm is triggered, does that mean that the load-balancing mechanism has failed? Are those alarms a 'safety net' for when the load-balancing can't occur?
A short background: I've used my 5090 Astral for a couple of months without issue, until the Asus software gave a warning about the pins fluctuating power too much (with the per-pin monitoring the Astral provides). I made sure to use the native 12v cable from the Seasonic PRIME TX-1600 Noctua PSU, and hadn't touched the cable since securely installing it a few months ago.
I'm aware that there are various triggers for alarms (such as temperature), but I'm mostly concerned with making sure the amperage distribution is somewhat stable for longer periods of time (+/- 10-12 consecutive hours).
Thanks in advance for your input!
Wednesday, May 27th 2026, 4:50pm
If the balancer cannot distribute the load in such a way that all lines remain within an acceptable range, the alarm management will kick in and, if necessary, will ultimately shut down the graphics card by cutting off its power supply as last measure.
tmvanveelen
Wednesday, June 10th 2026, 2:38pm
Thanks for your response! A quick follow-up: I received the Ampinel last week and I've used it quite extensively while rendering an animation. It seems to work great! However, I also noticed that sometimes pin-6 turns orange; the explanation states: 'increased contact resistance or load'. I kept monitoring the rendering process, and eventually the pin turned green again (without my interference on a software or hardware level).
What might be the reason for this recovery?
Thursday, June 11th 2026, 4:29pm
Depending on the temperature, the connector and its contacts may move slightly, which can sometimes result in varying contact resistance. If yours is switching between yellow and green, you're probably right on the threshold. You don't need to worry about it. Generally speaking, yellow pins aren't a direct problem either. It's just an indicator that the connection could theoretically be better. As long as there are no significant imbalances between the lines, I would not touch it. Bear in mind that every further unplugging/plugging puts mechanical strain on the contacts and may ultimately cause permanent serious problems.
If there is a real problem that requires attention, AMPINEL will warn you.
Big Sean
RE: Load-balancing logic vs escalation with alarms
Monday, November 2nd 2026, 1:52am
I know I'm reviving an old post but i feel that i have useful information to add since i have the same gpu & psu as the OP. The native cable that comes with the TX1600 psu is trash. I had consistent issues with contact resistance on pins 1 & 6 no matter how many times i reseated the cable on the Ampinel and psu with all new components. The instant that i replaced the "Native" POS cable from Seasonic with a CableMod 12vhpwr cable, all of my issues magically disappeared and have never returned. Now all of the pins show green in AquaSuite and i haven't had a single alarm go off with well over 20hrs of gameplay at full load in a variety of titles including Crimson Desert, Ace Combat 8, Gears of War E-Day, Forza Horizon 6, and Call of Duty Modern Warfare 4. I highly suggest that you get yourself a set of CableMod cables to replace the "Native" Seasonic garbage cables. Also never use the Lian Li Wireless Strimer RGB cable extensions either. Those also led to issues, the 24 pin Strimer was causing my 5V and 3V rails to droop which caused a few of my usb devices like the lcd screen on the front of my Cooler Master HAF 700 evo case to randomly disconnect and trigger that annoying windows usb chime at random intervals. Once i removed the Strimers and used exclusively the CableMod cables, all of my issues are gone. The Ampinel is a wonderful device and gives me a great piece of mind that my RTX 5090 Astral OC will be safe for many years to come in my custom loop system.
System Details
Asus PG34wcdn UWQHD Ultrawide Monitor with Asus ROG Aura Light Bar with Ergotron LX Pro adjustable arm with quick disconnect and grommet base
Acer Predator X27 4K IPS Monitor with Ergotron LX Pro adjustable arm with quick disconnect and grommet base
Cooler Master HAF 700 Evo Case
Ryzen 7 9850X3D with Alpha Cool Apex One Water Block
32GB DDR5 6,000MTs CL26 V-Color Manta X-Sky with EKWB Quantum Momentum Ram Water Block
Asus RTX 5090 Astral OC with EKWB Vector 3 Water block & Aqua Computer Ampinel device & Cooler Master GPU Holder with ARGB Tempered Glass
Asus Crosshair Glacial X870E
2x WD Sn8100 4TB Raid 0 array
Samsung 990 Pro 4TB
2x EKWB D5 Inertia G3 Pumps with Acrylic ARGB Top in series
Aqua Computer High Flow Next ARGB In-line Flow Sensor
FLT Kinetic 360mm D5 Reservoir/Pump Distro Plate
2x EKWB X360M Quantum Surface Radiators with Corsair LX120 & LX120R Fans in Push/Pull Configuration
2x EKWB P360M Quantum Surface Radiators with Corsair LX120 & LX120R Fans in Push/Pull Configuration
1x EKWB X240M Quantum Surface5 Radiator with Corsair LX120 & LX120R Fans in Push/Pull Configuration
2x Cooler Master Sickleflow 200mm ARGB Front Intake Fans
Razer Nommo V2 Pro 2.1 Speakers
Keychron Q6 HE 8K Keyboard
Razer Basilisk V4 Pro Mouse
Razer Firefly 2 ARGB Mouse pad
Desky Dual Hardwood Pheasant wood Sit/Stand Desk with 2x Grommets & Pheasant Wood under desk cabinet
This post has been edited 1 times, last edit by "Big Sean" (Nov 2nd 2026, 2:06am)
