• 22.11.2026, 20:29
anub1s21
Octo not working as intended after last firmware update
Thursday, October 29th 2026, 5:15am
after installing the latest firmware for the Octo the one that claims to fix curve controller startup behavior the octo just go's rogue for 3 min when i start my pc before it load my profile, is this intended behavior?
i can intervene and switch settings which will get it to work but having my fans blasting for 3 min (intake only, thank god water can absorb a lot of heat before it actually heats up) when i start my pc is exactly what i was avoiding with the octo.
picture attached of what aquasuite shows when the octo is off in never never land.
i have uninstalled and new installed aquasuite
i have done 3 factory resets
i am about to contact support to see if there is a way to downgrade the firmware or i'll have to wait for an update because if i have to take the octo out, i'm switching brands because that is an operation and i will not risk having to do it again because of software shenanigans.
anub1s21 has attached the following file:
  • Untitled.png (365.06 kB - 79 times downloaded - Last download: Today, 8:19pm)
This post has been edited 4 times, last edit by "anub1s21" (Oct 29th 2026, 5:28am)
Thursday, October 29th 2026, 8:45am
Take some screenshots where you can see in Aquasuite that the fans aren't working as they should.
In your current screenshot, the fans are doing exactly what's set— 0%.
anub1s21
Thursday, October 29th 2026, 12:03pm
sebastian are you fucking serious.
on the tab highlighted it is in IN curve controller at 23 degree's and thus the fans should be spinning in the 40% range not 0%
2nd if you'll note my SL-INF's these are also on 0% but spinning at 2100rpm (also curve controller).
for the love of god are you the only english speaking support because what you miss even in a screenshot is staggering.
it is infact not at all doing what it should, it is infact not working as intended and i am getting really pissed off that the default seems to be suggest all is well when the screenshot clearly shows the octo is not at all doing what it says it should be doing ffs.
at this point i am considering looking up every post i ever made praising aquasuite and editing them because what the fuck.
Thursday, October 29th 2026, 1:28pm
The fans don't start running until the startup temperature has been exceeded once.
It's always been that way.
I think you’d get a better response if you approached this a little more calmly. People are generally happy to help when the conversation stays respectful.
Quoted
I dont see any screenshot for this settings.
How precisely are the fans connected?
anub1s21
Thursday, October 29th 2026, 2:54pm
here you go sir 2 more screenshots to elaborate on the issue with the setup exposed so you can see in detail the things that are messed up.
the minimum temperature has been met, the minimum fan speed is ignored, the output is incorrect, the fanspeed is somehow correct.
litterally the only thing in the 1st screenshot i posted that is correct is the pump all 4 other fan's if you look at the top bar it seriously shows all you really needed to know, you will notice not 1 the first 4 entry's are actually "Correct"
now please again tell me how this is not the curve controller acting messed up at startup after a update was released that addressed the startup behavior of the curve controller
anub1s21 has attached the following files:
  • Untitled.png (370.85 kB - 54 times downloaded - Last download: Today, 8:18pm)
  • Untitled2.png (403.72 kB - 51 times downloaded - Last download: Today, 8:18pm)
Thursday, October 29th 2026, 9:02pm
Are the fans connected directly to the Octo, or do you have any cables, adapters, or splitters in between?
anub1s21
Monday, November 2nd 2026, 5:23am
the SL-inf's are daisy chained / directly connected to the octo, the NF-A's are split acros 2 splitty's which is connected to the octo.
same setup i've used in this pc for 2 years now, same setup i've been using for about 6-8 years now.
profiles do work but after ~ 3 minutes first 3 minutes it just does whatever it wants.
Monday, November 2nd 2026, 7:31am
I think it's just because it's a little colder right now that the controller is set to 0%. -> The fans are running at 100%.
Try clicking “hold minimum power.” If, after a while, the temperature briefly exceeds your 23°C and then everything returns to normal, that would explain the behavior you observed.
anub1s21
Wednesday, November 4th 2026, 2:51pm
and i am 100% sure that since this setup has run for 8 years 2 in the form it is currently in.
it is also currently fall not the middle of winter.
that this is related to the firmware update that got pushed with aquasuite X.96
quote from the change log :
Quoted
OCTO Firmware 1021:
QUADRO Firmware 1034:
  • Bugfix: Curve controller startup behavior
as soon as the device powers on...aka startup behaviour, it is not following the profile, upon starting my pc i'd say there's a 40% chance of aquasuite at some point pushing the profile through (as i sometimes just go screw it CBA and grab a coffee first and magically when i come back...it applied the profile...or the octo decided now is the time to do what the profile says). other times i see the temp threshold has been reachted, the minimum and fallback fanspeed are suggestions at best, and 2 fan's with 0% output are spinning flat out.
rename the previous firmware to something greater then the current one and push that or something since a roll back is apparently impossible (not the first time i've heard that so willing to believe it).
also correct me if wrong but the correct behaviour below 20 degree's would say if the water were 17...would be to pretend like it's 20 is it not? rather then treating sub minimal as a reason to go flatout or enter a not set up 0 RPM mode?
and i'm sorry but you realize your explenation is basically the octo is garbage?
reason the threshold gets reached within 30 seconds(almost instantly this time of year)...the octo responds...3-5 minutes later....this sounds correct to you? to trigger a threshold and eventually it responds cause to me it sounds like something is broken.
but really i am just getting sick of this judo bullshit you are pulling. your shit worked great, then you did a firmware update, now your shit doesn't work and you have been looking for ANY excuse to say it's not the firmware update that got forced through the software update.
either yer firmware is not working as intended or the latest aqua suite is not pushing the profile through correctly pick your poison and stop trying to flip this back on the customer.
if you note the 2nd batch of screenshots shows the sensor is reading a watertemp of 23....that's 3 degree's past 20 when it according to you should start working...it did not....the 2nd shows the fan is doing something completely different from what it is setup to do. yes both these work when i apply the profile and shut down my pc with all in working condition...and when i boot it up a couple hours later it's screwed up again.
almost....as if the damn startup behaviour of the curve controller was changed in some way and now no longer functions as it should
This post has been edited 8 times, last edit by "anub1s21" (Nov 4th 2026, 3:13pm)
Thursday, November 5th 2026, 11:49am
The input temperature (22.8°C) that you use for this controller is still below your start temperature (about 23.45°C). The fan output remains off as long as the input temperature has not exceeded the start value. Since the difference is relatively small, I assume that your temperature has been above the start value so far, and that is why the fan has been running continuously. Now, it takes a moment for the temperature to rise above the set threshold. You can change the start temperature by simply dragging and dropping the line further to the left.
Like above, the input temperature is still below the start temperature. Therefore the fan output is off (0% power). That you still get a RPM value tells me that you very likely use an externally powered fan hub on the channel. This hub still provides power to the fans but since there is no PWM signal due to the disabled fan output, the connected fans run at full speed which is a normal behavior if no PWM signal is present. Again, you could move the start marker further to the left or you enable the hold minimum power option and set a low value for example.
The only way to make this work correctly as currently being set is by using a more intelligent fan hub that also cuts the power if no PWM signal is present. Our SPLITTY9 ACTIVE is able to do that as it allows to set a threshold with a knob. If the input PWM signal falls below that threshold, the splitter will cut the power and the fans will stop.
All in all, there is no error here. It is simply a matter of settings. The latest firmware update did not change anything regarding the curve controller in this regard either. The behavior has remained identical and has never been changed since the device was launched. The current firmware update only fixed a minor bug where, even with start boost disabled, the fan would still start at 100% for a very brief moment at the beginning (after passing the start threshold). With slow starting fans, you don't even notice this. Well, with fans that spin up quickly, you could briefly perceive it, and a few customers had complained that this was annoying.
das1985
Sunday, November 8th 2026, 7:15am
I encountered the same issue after updating to the latest firmware. Upon a cold boot of the computer, the fans spin at 100%. After 1–2 minutes, everything returns to normal. If I launch aquasuite immediately, the readings suggest that the fans aren't spinning: the output power shows 0, and no RPM values ​​are displayed. This problem appeared specifically after the update to the latest firmware.
This post has been edited 1 times, last edit by "das1985" (Nov 8th 2026, 7:24am)
das1985
Tuesday, November 10th 2026, 4:14pm
Extending the curve to 0° did not help.
das1985 has attached the following files:
  • 01.png (572.48 kB - 34 times downloaded - Last download: Today, 8:18pm)
  • 02.png (111.15 kB - 14 times downloaded - Last download: Today, 8:19pm)
  • 03.png (33.4 kB - 19 times downloaded - Last download: Today, 8:18pm)
Tuesday, November 10th 2026, 5:54pm
you dont understand the behavior: 01.png
you have to move the START Temperature to left. Set the start temperature to 10°C.
That's how it's always been—for years!
Read the manual:
10.3. Fan mode curve controller
Wednesday, November 11th 2026, 12:20pm
To make it more clearly: start.png
das1985
Wednesday, November 11th 2026, 3:30pm
Thanks, I understand now. Everything is working correctly.
I hadn’t needed this slider for 4 years. It seems the weather has just turned colder, and I mistakenly linked that to the new firmware—my apologies.
