• 04.10.2026, 07:51
TYPOlight error
An error occurred while executing this script!
  1. If you are a TYPOlight user, contact the administrator of your website.
  2. Open file system/logs/error.log and search for a corresponding entry.
  3. Open file system/config/localconfig.php and add the following line:
    $GLOBALS['TL_CONFIG']['displayErrors'] = true;
  4. Visit the TYPOlight project page or search the TYPOlight forum.
pmcguire
Just got the 6800 waterblock.....
Wednesday, February 16th 2005, 11:30am
Some instructions would be nice guys, I mean really!
What are the plastic bolts for? Why do I have different length metal bolts?
Can I fit this block to the leadtek card? (looks pretty dodgy at the moment)
Bottom line is that this block costs 80euro, at least make an instruction PDF file.
SNTmods
Re: Just got the 6800 waterblock.....
Thursday, February 17th 2005, 5:35am
Its a common sense install lad. Your 4 metal screws are used around the chipset with the included plastic washers. The plastic screws are used on the outside of the card. Just be easy when bolting the block down and work from inside out so you reduce the flex of the card.
-Dan
Was an early adopter of Aqua-Computer watercooling in the U.S.
maverick72
Friday, February 25th 2005, 6:38pm
Quoted from "SNTmods"
-Dan
Altrought I partially agree with the common sense I also agree with the request ... it would be nice.
I got all my stuff in one box .... nothing was telling me those screws go with those holes and stuff ... damm I don't even know what he is talking about for the plastic bolts ... I never got them :)
aviddigi
Friday, February 25th 2005, 11:40pm
I'll put a third on that, some stuff is easy to figure out/ put together but instructions would be nice and some support going on two weeks with no replys about my aquaero and aquastream pretty weak.
Maverick you posted over at hardforum also correct, how did you fix your aquastream problem?
