• 12.11.2026, 19:52
maverick72
pump starts .... and stops ... aquabus error light
Saturday, February 19th 2005, 6:26pm
Need help bleeding my systems ... got all the leaks .. filled my reservoir ... started the pump ... loop looks good ... BUT pump stop for a second ... error light comes on ... pump goes back on for couple of seconds.
What i'm I missing?
edit: I got the 3 red blink which is
pumpe nimmt keinen strom auf oder ist nicht angeschlossen
Which according to babelfish ...
pump takes up no river or is not not attached
That really isn't helping :)
Re: pump starts .... and stops ... aquabus error l
Saturday, February 19th 2005, 6:36pm
Maybe the jumper of the deaeration-mode is set. It's the one on the right.
1x flash impulse of the red led means that your psu doesn't deliver enough power (below tolerance of 12V).
maverick72
Saturday, February 19th 2005, 6:38pm
Quoted from "Shoggy"
The psu is a antec 420 true power which should be alright.
What does that jumper do and more important ... where should it be :) ... thanks alot for your help.
Saturday, February 19th 2005, 6:42pm
If the jumper is set the pump will run for some seconds, will stop, run, stop and so on ;D
This mode is used to get rid of air within the components.
Without the jumper the pump is runnig in a normal way.
back_orifice
Saturday, February 19th 2005, 7:12pm
But this all just works when u have the AS... ;D ;D
maverick72
Saturday, February 19th 2005, 7:55pm
Quoted from "back_orifice"
All good ... thx guys :)
aviddigi
Tuesday, February 22nd 2005, 3:56am
Did you figure out the problem?, i have been fighting with my AS and now it is giving me 3 red flashes. Tried to email AC for the past week about warranty info or help with no response. All the jumpers are where they should be set up the same as my current working setup.
Thanks
Halk
Thursday, March 3rd 2005, 8:43pm
According to the manual, 3 red flashes means the pump is not receiving power or is not connected correctly.
You haven't accidentally undervolted it?
There's a link to the manual for it in English somewhere on the site, the manual is well written too.
Thursday, March 3rd 2005, 9:03pm
FYI: the "problem" was the deaeration-mode ;)
