• 29.11.2026, 18:48
f4brice
Got my Aquaero ! Some questions...
Wednesday, March 16th 2005, 1:37am
Hi all !
I received a few days ago my Aquaero !
Yeahhh ! It really roxxxx ! :D :D :D
I've hardware v4 and embeeded sofware v3.99D
I have some questions about it :
1/ I want my Aquaero to display english messages (my german is sooooo bad) ; I read in this forum that I just need to :
- start aquaeroUSB
- select English language
- download a firmware
but mine has already the latest firmware.
What can I do ?
2/ aquaeroUSB always start in german and with a very small size (I'm using v1.0.53). Is it possible to have it :
- remember and use the last selected language ?
- remember and use its last window size & position ?
3/ aquaeroUSB & the Aquaero are both very slow-responding to user actions (mouse clic / button press) :( Will this be improved with v4 ?
Best regards and continue the good job !
Fabrice
f4brice
Re: Got my Aquaero ! Some questions...
Wednesday, March 23rd 2005, 9:51am
Nobody here to answer my questions ? ???
Also, I've sometimes 2 small problems with my Aquaero :
1/ sometimes my computer doesn't "see" it and I have a yellow "!" on an USB connector in the device manager. I have to disable & re-enable the USB output to make everything work OK. I've seen this on the German forum, but I can't undertstand the answers. There's also a menu for this in the Aquaero, but I don't known what value to set there.
2/ sometimes my Aquaero fails to measure the max speed of my 12 cm fans. It sometimes thinks it's 800 rpm but it's actually 1200 rpm.
I set the minimal RPM to 50%, my fans don't spin at 400 rpm. So the Aquaero sets again max power, and decrease it and so on... :( Any solution ?
Best regards.
Wednesday, March 23rd 2005, 4:17pm
1.) You need the fimrware 3.99D file to flash the aquaero with the correct language. This file is not available for download. There will be a new firmware... (more at 2.)
2.) Currently it is not possible to save the settings. In a few days there will be a completly new version of firmware and software. You cann see three preview-screenshots here.
3.) This problem should be fixed with the new software.
4.) You can use the USB-delay. You will get this feature when you press set and go to Menü Einstellungen Anzeige-Parameter -> USB-delay and choose aktiviert. Next time you start the pc the aquareo will wait a few seconds before it tries to log on to USB.
5.) Maybe fixed with the new firmware; no idea.
Well, short summary: the new soft- and firmware hopefully fix all the problems.
