• 15.11.2026, 18:41
jmisola
Aquaero questions
Wednesday, March 30th 2005, 7:34pm
I am planning to buy an aquaero for my watercooling system.
I would like to know if it is possible to connect a flowmeter from innovatek (rev 2) and a relay PumpControl-O-Matic from innovatek ?
Does I need to buy other accessories for that ?
Thanks a lot for your answer.
Regards
Top_Nurse
Re: Aquaero questions
Wednesday, March 30th 2005, 11:42pm
Someone from A-C will probably have to answer the question about the Control-O-Matic as I know nothing about it.
The Aquaero info I have shows that the software will allow you to adjust the calibration for different manufacturer's of flow devices. So I suppose that you probably can hook it up providing that the connectors are the same or you modify them yourself.
The calibration factor intrigued me as I have been concerned about reported flow reduction in the A-C unit. I figure if I check the flow with the standard A-C unit and then bore open the holes through the unit as possible I then can recheck the same flow reading and adjust the calibration factor so it reads the same as before with less flow restriction ;D
