• 02.09.2026, 17:24
mindwarp
Water Circuit Problem
Wednesday, April 6th 2005, 12:05am
My problem is the following i have been preparing my system for the past few weeks and have almost all the hardware, but i have one doubt the route of the water through the components i was thinking of spliting the cables but i have read here in the foruns that problems may arrise from such a setup, so would apreciate your input in this as this is my 1st watercooling experience.
So this is the stuff i will be connecting:
AMD 64 FX-55
ATI Radeon X850XT-PE
Asus AN8-SLI Deluxe
Westen Digital Raptor 79Gb
2 x Maxtor 300Gb 16Mb Cache
Aquastream
AquaTube
Airplex Evo 240
Airplex Evo 1800
Cuplex Pro
Twinplex for Chipset
Twinplex for ATI
Aquadrive
Dual Aquadrive
So my first thought at the time was:
Aquatube - Aquastream - Evo 1800 - Split = Cpu + Gpu = Rejoin - Evo 240 - Chipset - Aquadrive's - Aquatube
So what do you think?
Any help would be apreciated
Thks
Re: Water Circuit Problem
Wednesday, April 6th 2005, 12:16am
Do not split the circuit. You can not make sure if both componentes will get enough water. Splitting has no advantage.
mindwarp
Wednesday, April 6th 2005, 12:37am
Ok thks but about the order do you think cpu-gpu or the other way arround is bether my problem here is that both components release a lot of heat won't the heat realeased from one component increase the temperature of the other?
Top_Nurse
Wednesday, April 6th 2005, 1:37am
Splitting lines is very advanced [H] water cooling. Don't recommend you do it till you know exactly what is going on and how to adjust things. ;D
Top_Nurse
Wednesday, April 6th 2005, 1:42am
Quoted from "mindwarp"
Actually not as much as you would think as everything gets hot. The difference is negligible. There are solid reasons for splitting lines, but this is not one of them and as I indicated it is highly advanced water cooling. Do yourself a favor and don't split your lines or you will be :'( about burned up computers.
Wednesday, April 6th 2005, 2:29am
The order doesn't really mater because the water temperature is almost the same at every place within your circuit.
It's time for one of my unique examples to explain this.
Let's start with a picture ;D
Imagine you would move your finger with a fast speed across the plates and finally put it in water. I would say you should be ok after this and could do it again and again ;)
But what would happen if you move your finger slowly across the plates?
Mhhh, do you smell this too? :-X ::)
And now imagine the finger would be the water in your circuit, the plates are CPU, GPU and CS, and the water would be our radiator.
edit: I forgot something... KIDS, DON'T TRY THIS AT HOME!
Wednesday, April 6th 2005, 3:36am
Quoted from "Shoggy"
I'm lying on the floor... it's to stupid for my smashed brain... ;D
Or witsh other words: LOL!
But shoggy is right!
Man In Blue
back_orifice
Wednesday, April 6th 2005, 4:59pm
Hmm, there should be an "Shoggy Encyclopedia" with all his posts in it...
;D ;D
here it fist: roflmoa
Top_Nurse
Wednesday, April 6th 2005, 5:18pm
ROFLMAO
But I like it! Shoggy are you sure your not a misplaced artistic type. We have a nice spot for you in the Laguna Art Festival
mindwarp
Wednesday, April 6th 2005, 11:54pm
Thks again for the explanation specially Shoggy for the ilustration simple but efective way of putting the things :)
