• 08.10.2026, 08:22
Mr_modnaR
take it out, but leave it in
Tuesday, April 19th 2005, 10:16pm
hi, just read about the "BaDassII" over on wizardforums. the creator of that thought that connecting the reservoir with a t-piece, and using only one of it's connectors:
| Aquatube |
|_________|
_________ | |___________
Water flow-> _______________________
is a good way of reducing restrictions in the system. Now to me this seems like a good idea, is there any reason why i shouldn't do this? (apart from not getting the aquajet working :'()
Top_Nurse
Re: take it out, but leave it in
Tuesday, April 19th 2005, 11:11pm
Quoted from "Mr_modnaR"
| Aquatube |
|_________|
I'm not sure I see how this would work? Can you explain better or provide a link? Does the other side of the T go back to the reservoir or is it just plugged? Or are you using the reservoir as just a place to off load extraneous water flow?
Mr_modnaR
Tuesday, April 19th 2005, 11:23pm
please excuse the drawing, i've just noticed it! Right what i mean is: the aquatube is mounted at the highest point of the watercooling loop, ie at the top of the case. instead of having two p&c connectors screwed into it, you just have one. this drops down to a t-piece. the 'long' side of the t-piece (the straight bit) is inserted into the top portion of the water loop. in other words, once the system is filled, you have in effect a straight through connector, with little or no resistance. if the water level drops a little, extra water comes in from above from the aquatube. i work in the motor trade, and all modern cars have a header tank in their water systems. this header tank is not involved in circulating water in most cases, but just there to provide room for expansion, and to top up the water level. i hope you can understand this, i know i haven't explained it very well.
CyberXY
Wednesday, April 20th 2005, 12:16am
I think you can do that if you want, but the resistance in a Aquatube is nearly zero compared with the one of a cooler, especially compared with the Cuplex Pro/XT.
Infiltraitor
Wednesday, April 20th 2005, 12:55am
I think that it's used as an air trap
Mr_modnaR
Wednesday, April 20th 2005, 1:26am
i guess you're right people! thanks for the input! at least i can put that aquajet to good, if entirely aesthetic, use now! ;)
dutchcedar
Friday, April 22nd 2005, 6:20am
Well, I'm the designer and builder of BaDassII... she's been performing like a racer ever since the day I fired her up... in fact she now powers three 21 inch Samsung flat panels instead of CRT's.
You're right Mr_modnaR... it works like a header tank and makes sure air never enters the critical cooling loop. The flow also by-passes the reservoir entirely, which probably helps the flow a bit, although that wasn't the main purpose.
If you're interested, here's the entire article: http://www.pcper.com/article.php?aid=41&type=expert
dutchcedar
Friday, April 22nd 2005, 6:28am
For what its worth, I'm waiting on a reservoir from Germany at the moment that will be used in the same way. Common sense, practice and experience tell me there is absolutely nothing to gain from moving coolant through a reservoir. It doesn't improve performance, flow or cooling... so what's the point? It purpose is plain... keep the loop full. There simply is no reason to run coolant through it to meet that objective.
