• 17.11.2026, 13:12
Top_Nurse
TEC modified A-C coolers?
Wednesday, May 4th 2005, 11:44pm
Greetings...
Anyone put a TEC on a XT or a Twinplex?
Hummerman
Re: TEC modified A-C coolers?
Thursday, May 5th 2005, 2:42pm
What means TEC?
Mr_modnaR
Thursday, May 5th 2005, 9:31pm
a Thermo-Electric Cooler. aka Peltier Cooler, has a 'hot' side and a 'cool' side, you apply voltage across it, and it makes the 'cool' side cooler, and the 'hot' side hotter.
so the cool side goes on the cpu, which gets actively cooled by the TEC.
and the hot side goes onto a heatsink (or water block), and transmits its heat to the air (or water).
if your heatsink (or water cooling system) can shift the heat quick enough, you get a very cool cpu 8).
here endeth the lesson :P
Hummerman
Friday, May 6th 2005, 3:22pm
Thanx. I only knew the word Peltier for this.
Bad english? :D
Top_Nurse
Friday, May 6th 2005, 10:14pm
Quoted from "Hummerman"
Bad english? :D
Nope. :) Just that TEC has become so widespread that I thought everyone knew what it is. Forgot that when posting to a foreign site that these kinds of abbreviations are not so obvious as your's might be AQU. ;) ;)
However, what I'm thinking of is to mount a peltier on to the bottom of a Twinplex x 2 for a SLI rig I'm building. These Asus 6600 GT cards run quite hot...even hotter than the CPU's :o So me thinks that a peltier equipped A-C solution sounds fun and dooable. Just wanted to know what others had done before?
Mr_modnaR
Friday, May 6th 2005, 10:28pm
if you could get hold of longer plastic bolts (or risk using metal ones with plastic washers) i wouldn't have thought there'd be a problem. the only one i can think of would be, that the tec would need to have a means for locating it onto the cpu, so that it didn't slide about! ;D. you could make your own plate for it that had holes in the same place as the twinplex and put the longer bolts thru both.
Top_Nurse
Saturday, May 7th 2005, 3:09am
Actually I have been thinking of milling in a pocket to hold the peltier in place on the bottom of the Twinplex. After I get them I will see how much room I got.
Mr_modnaR
Saturday, May 7th 2005, 3:37pm
genius! 8) (didn't think of that!) plus it'll give you better cooling, unless you mill too much away, in which case, you'll get wetter graphics cards! ;D
Top_Nurse
Sunday, May 8th 2005, 9:15am
Most of the time it pays to think out of the box ;) I figure it won't need much in the way of milling really as it only has to provide a ledge to locate on and not slide out. If it works well I will also try the same thing on my XT. The Twinplexs will be here next week so I figure a week or two for my friend to do a G-Job for me. I'm not too concerned about the abilty of the Twinplex's to move TEC heat, but I'm not sure if the XT will be able to move that much heat or not.
Mr_modnaR
Sunday, May 8th 2005, 12:39pm
the thing with the xt is that it's designed to be more effective at cooling the centre of a cpu, where it's hottest. i think the tec would give a more evenly spread heat on it's hot side, so you may find that it's doesn't remove enough heat round the edges, which would result in slightly higher temps on the cold side.
of course this is just speculation (edit: or bullsh*t  :D) so unless someone else has done this before, it's up to you to find out!  8)
"go where no man has gone before" and all that....
