• 08.10.2026, 06:10
Mr_modnaR
Aquastream 3-pin fan connector
Sunday, May 8th 2005, 7:23pm
does the 3-pin fan connector on the aquastream controller board still give out a tacho signal to connect to the mother board when it's connected to the aquaero?
cheers
x-stars
Re: Aquastream 3-pin fan connector
Sunday, May 8th 2005, 8:26pm
The 3-Pin-Connector is for the motherboard to control if the aquastream is working correctly - DON't CONNECT IT TO THE AQUAERO, it can destroy both ;).
Mr_modnaR
Sunday, May 8th 2005, 8:46pm
thanks for the answer, but i knew not to do that ;D
i meant: does the aquastream control board still give the fan signal out to the motherboard when it is connected to the aquaero (via the 10-pin cable NOT the fan cable!) as opposed to stand-alone operation?
x-stars
Sunday, May 8th 2005, 9:22pm
Quoted from "Mr_modnaR"
Ups, then I missunderstood :p. Well, I haven't got an aquastream and my aquaero is in hardware-heaven, so I can't check it (but I think, the pump will send the singnal, why don't you have a try?)
Mr_modnaR
Sunday, May 8th 2005, 9:31pm
:'( cos i'm afwaid <sniff>
only kidding! it's cos i ain't got me aquaero yet!
just need to know, cos i'm not sure if my mobo needs a signal on the cpu fan to turn on.
Mr_modnaR
Monday, May 9th 2005, 4:56pm
anyone? ;D
