• 09.10.2026, 06:53
Mr_modnaR
Aquabay CF pics?
Sunday, May 8th 2005, 3:22pm
Hi all...
does anybody have any pics of the rear of an aquabay cf? in particular the mountings for the screen?
cheers muchly!
Top_Nurse
Re: Aquabay CF pics?
Monday, May 9th 2005, 1:57pm
http://www.aqua-computer.de/prodimg/nd_p…f_seite_200.jpg
I think the only difference is that the front panel has a bigger hole. Otherwise I believe it is the same.
Mr_modnaR
Monday, May 9th 2005, 4:42pm
what i meant was: how does the lcd screen attach to the aquabay? is it to the side mounts? or is it to the front panel?
(that's why i needed a pic of the back :D)
cheers anyway top nurse!
Top_Nurse
Monday, May 9th 2005, 10:19pm
I don't think it attaches to the front plate.
Mr_modnaR
Monday, May 9th 2005, 10:41pm
Thank you! i found this pic, and it looks like you're right:
http://www.aqua-computer.de/cgi-bin/shop…abay_15_500.jpg
looks like it's the same aquabay for the aquatube and the lcd screen, they just use a different front plate. the screen appears to be attached to the mounts that are set back from the front.
